finally got pyrometer installed
Old Mar 27, 2009 | 11:20 PM
  #31
88f150302's Avatar
88f150302
Originally Posted by dyoung14
dang why? lol
well it probably gets better now with the different gears but i had 36s on it with 3.08 gears with 31s on it it wouldnt shift into overdrive till it hit 85mph now i have 4.11 gears and 38.5swampers on it i havent checked since the new gears and tires cuz it is not on the road enough to check it
Old Mar 27, 2009 | 11:31 PM
  #32
S.P.'s Avatar
S.P.
who needs a pyro anyway, when you start hearing wierd sounds thats when you know to take your foot out of it. dont every one drive that way?
Keep your foot in it till you see aluminium DRIP out the pipes, THEN kinda let off it...
Old Mar 27, 2009 | 11:35 PM
  #33
starmilt's Avatar
starmilt
Originally Posted by joe f350
iam never going to live it down aim i but i have a pyro just havent put it on yet dont realy know where to put it
Are you nuts we have to have somebody to pick on.
Put it as close to the back of either manifold as you can.
Old Mar 27, 2009 | 11:38 PM
  #34
starmilt's Avatar
starmilt
So you don't get any shavings from the drill in your exhaust use a 24 ounce ball peen to drive the stinger in lol.
Old Mar 27, 2009 | 11:47 PM
  #35
dyoung14's Avatar
dyoung14
o cool cool
Old Mar 27, 2009 | 11:56 PM
  #36
dyoung14's Avatar
dyoung14
yea that also works too and the post above this one was to something else, i just forgor to quote it lol, im getting a little tired
Old Mar 28, 2009 | 12:37 AM
  #37
joe f350's Avatar
joe f350
sleep is for the weak
Old Mar 28, 2009 | 07:44 AM
  #38
galute's Avatar
galute
Or those that have a job.
dyoung14 if you're pyro is close to right then you're not getting enough air. Think of it like this. Turn the gas on on a cutting torch and light it. The flame is cold with lots of black soot. Start turning the oxygen to it and the flame gets hot enough to melt metal. Hit the air button and it will start cutting thru steel. You say you are blowing lots of black smoke which means you are flooding the engine with fuel. Since you can't get more air in without a turbo cut the fuel back some and I would bet the exhaust temps will start to come up.
Old Mar 28, 2009 | 09:03 AM
  #39
dyoung14's Avatar
dyoung14
i think im just going to leave it alone until i get my turbo hooked up, also and i went to bed at 12 am last night, joe, who dont belive in sleep, if its 12 in tennessee then its what 9 or 10 in cali? am i correct
Old Mar 28, 2009 | 09:43 AM
  #40
f350custom's Avatar
f350custom
i run the isspro brand pyrometer in my pete . i run it to 1,000 degrees max any thing higher i down a gear . around town it runs right around 600 degrees. i know its a 3406C cat motor but a motor is a motor they all melt down the same been there done that. an black smoke is just unburnt fuel . low exhaust temp = rich fuel mix,no load .. high exhaust temp = lean fuel mix ,heavy load . now to make power lean is mean just watch pyro an detonation. isspro has some info on the web site
Old Mar 29, 2009 | 01:38 AM
  #41
1994diesel's Avatar
1994diesel
huh?
I thought that diesels ran cool with a lean mix and hot with a rich air to fuel mix. and gasoline engines are the exact opposite of that.
Old Mar 29, 2009 | 02:02 AM
  #42
S.P.'s Avatar
S.P.
Originally Posted by 1994diesel
huh?
Me thinks the mans rite...
??? ANYONE???
Old Mar 29, 2009 | 02:37 AM
  #43
82F100SWB's Avatar
82F100SWB
Yep, the man has it right, diesels are the opposite of a gas engine when it comes to this. Lean out a Gasser, and it gets hot, lean out a diesel and it run cold, hence why they don't make any big amount of fuel idling.
And, as for detonation, if you don't have it happening in a diesel, you don't have a running diesel... LOL
Old Mar 29, 2009 | 08:43 AM
  #44
dyoung14's Avatar
dyoung14
that kinda what i was thinking
Old Mar 29, 2009 | 11:26 AM
  #45
Dave Sponaugle's Avatar
Dave Sponaugle
Since a full charge of air enters the cylinder on every intake stroke and the amount of fuel injected is what varies engine speed, lean and rich do not apply to diesel engines other than rich is when the engine tries to go faster, lean is when it is slowing down.
