Cleaning EGR
Old Mar 25, 2009 | 09:00 PM
1bddelx's Avatar
1bddelx
Cleaning EGR
What should I use to clean it? Thanks Jeff
Old Mar 25, 2009 | 09:09 PM
UGA33's Avatar
UGA33
I have used brake cleaner all 3 times. I put electrical tape over the two holes and over the connector port on top of the valve and spray the **** out of it!
Old Mar 25, 2009 | 09:11 PM
1bddelx's Avatar
1bddelx
Great Thank You
Old Mar 25, 2009 | 09:36 PM
1bddelx's Avatar
1bddelx
Man that thing was caked. All clean and shiny now. Thanks again
Old Mar 25, 2009 | 09:56 PM
bismic's Avatar
bismic
Just an FYI - Ford states that there is a shaft seal that is softened by brake cleaner. They state to use only Carb cleaner because ....... any cleaner has great wicking properties. Spraying the valve and the stem will expose the cleaner to the shaft seal as the cleaner flows and penetrates the gunk. To prolong the life of the shaft seal, use only Carb cleaner. Covering the holes that are open to the inner parts of the actuator is an absolute MUST with any cleaner.
Old Mar 25, 2009 | 09:58 PM
1bddelx's Avatar
1bddelx
Thanks bismic, I did something good then because all I had was carb cleaner.
Old Mar 25, 2009 | 10:59 PM
UGA33's Avatar
UGA33
I have been following the article in the tech folder which states brake cleaner. Might want to see if you can get it revised Mark.
Old Mar 26, 2009 | 06:30 AM
bismic's Avatar
bismic
Thanks for the post - it may be hard to get changed, but I will float the suggestion.
npccpartsman noted on post #91 (page 3) of the tech folder thread to not use brake cleaner. Pretty hard to find that note in the whole thread!!
At about 1:40 seconds into the Ford video below, they make the recommendation to not use brake cleaner:
<TABLE style="WIDTH: 327pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=436 border=0 x:str><COLGROUP><COL style="WIDTH: 327pt; mso-width-source: userset; mso-width-alt: 15945" width=436><TBODY><TR style="HEIGHT: 25.5pt" height=34><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 327pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 25.5pt; BACKGROUND-COLOR: yellow" width=436 height=34>mms://multimedia.ford.com/seopts/Tech_31_250k.wmv</TD></TR></TBODY></TABLE>
Also:
<TABLE style="WIDTH: 660pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=880 border=0 x:str><COLGROUP><COL style="WIDTH: 660pt; mso-width-source: userset; mso-width-alt: 32182" width=880><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext 1pt solid; WIDTH: 660pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: silver" width=880 height=17>Carb Cleaner recommendation (see link below and refer to old TSB 06-19-6):</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: silver" height=17>http://www.forddoctorsdts.com/articles/article-06-12.php</TD></TR></TBODY></TABLE>
Old Mar 31, 2009 | 10:55 PM
Demolishus's Avatar
Demolishus
If you opt to clean the egr valve, dont forget to clean the ports inside the intake while its apart. I use a shop vac with a small flexible tube duct taped to the hose. youd be amazzzzed at what you find
Jeff K
22
Sep 9, 2013 06:13 AM
DR Smith
Apr 27, 2012 08:05 PM
jeffz
Sep 23, 2010 06:49 PM
jeff303
Appearance & Dress-Up
Jun 11, 2004 09:11 PM
