Best way to clean out a gas tank??
I finished draining all the nasty gas out of my 48 F3's tank last night and plan to take the tank out and clean it this weekend. Any advice on the best way to clean all the sludge out from the bottom of the tank...I was thinking about high pressure washing it but don't know if this is advisable...any thoughts? Thanks. Jeff K
I like to start with steam cleaning it. I set up an old galvanized gas can with water in it on a propane burner, set the tank upside down and run a steam hose off the can up and into the fuel tank and steam away for 1/2 hour or more. I am reluctant to coat the tank since gasoline formulas have and will continue to change. What is good for todays fuels may not be ok for tomorrows fuels.
If you want ti DIY, here's how I did it: Years ago we'd hang the tank up from a tree or beam like a swing or set it in a wheelbarrow, Fill it about 1/4 full with a strong hot water and detergent solution (we used Tide, but today I would use 1/2 bottle of Dawn) throw in a 4' length of tow chain and/or a large handful of large bolts and nuts (Hint: count them before and after) seal over the openings and vigorously shake the thing as much as your arms can stand. (Hint #2: since you live out in the country, make it a "Tom Sawyer" project, buy a couple pizzas, ice down some tea or sodas, invite all the kids around you to come over a see who can get it to make the loudest noise when they shake it. ) Pour out the dirty soapy water, rinse and repeat until the rinse water comes out clean. Dump out the chain and bolts and rinse with a gallon or two of the hottest water you can make. Pour in a quart of denatured alcohol, slosh around thoroughly and empty, Set out in the sun to dry. Go to your nearest private airport or private section of a public airport that has a parts department or to a motorcycle shop that builds choppers and buy a quart of "gas tank sealer and slushing compound" (You can buy it from Eastwood but it will likely be cheaper to get it locally).
Follow the directions on the can for using it. Basically you pour it in swirl and tilt the tank until all the inside surface is coated then dump out the excess and let dry.
i'm with AX on this one. something else that is cheap and works for de-rusting where you cant touch or see, is distilled white vinegar. it destroys the molecular bond the rust has on the metal. a few gallons sloshed with something to break the scale up can work wonders. I am in the same situation on my 49 F3 tank. no fuel in it, but lots of brown funk and rust
