Desktop dyno request - '70 429
'71 429 block, .030 over
'70 D0VE-C heads, stock w/ 1.7 roller rockers
stock rotating assembly, 10.5:1 or so
Edelbrock Performer 460
Holley 600 (though an Avenger 770 is planned)
stock exhaust manifolds
Cam: 204/214, 107/117 @.050
Timing is set at 6* advanced (I think)
Help anyone? Considering stock is 360hp, I think I'm close to 400 hp...I know the lack of headers is choking me up a bit, but that'll be in the works also.
Rest of driveline is NP435, NP205, going into '64 shortbed fleetside, 33's, 7" of lift...pics to follow.
Next Q - recommendations for headers? What kind of gains could I expect to see here?
Anyway here is what the WerbyFord Gonkulator computer says about your build:
The factory 429 T-Jet from 1968-71 was about 325hp on a good day, not "360".
(Do you really believe the T-Jet was 360hp and the SuperCJ was 370hp?)
With factory iron exhaust your build computes to
Torq 470 at 2800
Powr 336 at 4300
With 1-3/4 or 1-7/8 headers (either is ok)
Torq 491 at 2900
Powr 372 at 4200
It is set up just fine for a truck. The thing is, the Perf intake is just about what the stocker did, probably better MPG though (and lighter). And that cam, at 204-214 duration, is only a little bigger than the stock cam at 193-206 duration. So your build only gains about 11hp but that makes sense.
I'd look for an old 429scj iron intake, they are $100 or so and as a factory part always re-sellable. They work - even though the ports don't match.
And headers for sure.
Also, PAW/SSI sells a clone of the 429cj cam which works well at 218-228 duration, but still streetable in the Michigan winter, been there, done that.
The 600cfm carb is ok but these engines do like more, I used to get my best times from a 715 Holley and an 800 double pumper even on a couple mild (<400hp) engines.
