comp ratio
Old Sep 24, 2009 | 12:28 AM
jlang's Avatar
jlang
comp ratio
what comp ratio will i have with a stock crank and conn. rods (429) and the 413np pistons from federal mogoul i believe with the 12cc dish a .040 bore block and c8 heads wich i think are 72cc
i need to be up to 10:1 is this going to be enough or will i have to deck the block/ new pistons
Old Sep 24, 2009 | 12:37 AM
85e150's Avatar
85e150
Hhhm, more info needed. With a .040 head gasket the same diameter as your now-4.40 bore, 0 deck, & your other numbers, I get 13.78.
This is a 429, correct?
Put in your info here:
http://www.csgnetwork.com/compcalc.html
Head gasket thickness and diameter, and how far down the hole is the piston at TDC?
Old Sep 24, 2009 | 05:19 AM
monsterbaby's Avatar
monsterbaby
Not sure what numbers you used to come up with that high of compression, but a 3.59" stroke, 4.400 bore, 12cc valve relief, 72cc chamber .041 thick gasket (typical felpro head gasket thickness) and zero deck ends up at 10.49. Leave the pistons down .010 and it's 10.25
Old Sep 24, 2009 | 01:14 PM
85e150's Avatar
85e150
I went back to the calculator above. Got the same results. Tried another calculator and got the same as you did.
http://www.rbracing-rsr.com/compstaticclalc.htm
So I went back and found my error. I used a positive value for the piston relief. I changed it to -12, and came up the same as you, at 10.49xxx.
Thanks for the correction.
gus11208
16
Mar 4, 2016 11:35 AM
dying breed racing
21
Oct 13, 2014 01:11 AM
Frankinstine
20
May 30, 2014 02:46 PM
FossenRacing
Jan 29, 2014 05:24 PM
umdstang
Apr 28, 2005 04:58 AM
