P 1211 Code
Old Mar 22, 2009 | 09:44 PM
lazerf250's Avatar
lazerf250
Question P 1211 Code
Lately i have been throwing the p1211 code and it says injector pressure above/below desired level. I have a 17* pump and it never did this when i first put it in. Is there a way to measure the pressure the pump puts out or could there be any other thing going wrong. I can even throw this code in my economy tune?? The truck really dies out top end.
Old Mar 23, 2009 | 04:08 PM
Cuda_jim's Avatar
Cuda_jim
1211 = If set during normal engine operation, indicates engine is operating in open loop control and injection control pressure is above or below desired pressure.
If set during KOER test, indicates ICP system failed step test and could not maintain commanded pressure
Here's the test:
File Type: pdf
Old Mar 23, 2009 | 08:36 PM
lazerf250's Avatar
lazerf250
thanks is it possible for the ipr to be causeing this problem because the pump is out of a superduty that had about 120000 on it??
EMD_DRIVER
Sep 17, 2014 03:59 PM
jgilrfr
Dec 3, 2013 06:38 PM
Easy
13
Dec 20, 2006 08:18 AM
Stump Puller
18
Jul 4, 2006 10:56 AM
79CEEJAY
Feb 15, 2004 10:51 AM
