Steering in a bind!!
Old Mar 23, 2009 | 06:02 PM
97 RED PSD's Avatar
97 RED PSD
Was driving to work today and noticed that all of the sudden the steering wheel seems to bind up at certain points and it always seems to be random when it does this. I have been able to overcome the binding and the truck will steer correctly but I am thinking there is something wrong inside the gear box? Maybe a tooth broken? The box has always been a bit loose and I have adjusted it twice, once about 2.5 years ago and the other a little over a year ago. Each time per the manual. The steering tightened up some but then seemed to get looser. Just now has the binding started and I am scared to drive it much. Any ideas on how to diagnose or what to look for, or am I correct in thinking it is likely the gearbox? If so, how bad are they to change out and where is a good source for one? Thanks in advance!! Really gotta get this thing going soon as it is my DD. PS...219,000 miles 4WD Manual
Old Mar 23, 2009 | 06:14 PM
427 fordman's Avatar
427 fordman
I'd say its the gear box for sure. When you tighten them up if you go too far they will bind just like you are saying. I don't know how bad they are to change though cause I've never done it. Someone here sure has.
Old Mar 23, 2009 | 06:56 PM
97 RED PSD's Avatar
97 RED PSD
The part that gets me is that was well over a year ago when I adjusted it and there was no binding at all after I adjusted it. I have been hearing noises coming from the steering column and did some reading on the upper bearing? Is there a way to get the steering wheel off w/o a puller?
Old Mar 23, 2009 | 08:23 PM
Aireeek's Avatar
Aireeek
This is a common problem with our trucks. The steering wheel contains bearing the guide it while turning. After time these bearings go bad and have to be replaced. Its not a hard job or an expensive one, you just need to get a good diagram and pay careful attention to how you remove them so you can put it all back togeather correctly. You will need a puller.
Reek
Old Mar 23, 2009 | 08:36 PM
cowmilker08's Avatar
cowmilker08
If there is play in the wheel, then it is likely the upper and/or middle bearing in the steering column. this happened to me about a month ago. it costed $260 at a dealer.
Old Mar 23, 2009 | 09:05 PM
97 RED PSD's Avatar
97 RED PSD
Pretty sure this is the problem. Spent a couple of hours tonight taking everything apart. Didn't have a puller so I got the whole assembly off without pulling the wheel. Will have to round up a puller to get to the bearings. Probably should replace them all while I am in there. There is a lot of noise coming from where the spring scrapes on the snap ring on the top portion. Is there supposed to be something there to protect from that or should I just grease it up good?
rderr
13
Aug 28, 2013 06:35 AM
OldStroker
Jun 3, 2009 07:53 PM
smandzak
Dec 28, 2006 01:06 AM
Skoozo
May 24, 2003 08:44 PM
kurt russell
Oct 8, 1999 11:41 AM
