7.3L E4OD swap to C6
Depending on the year, the speedometer sensor was moved from the transmission and incorporated into the anti-lock brake sensor circuit mounted in the rear end, even if your vehicle did not have anti-lock brakes.
If your truck has no need for the C6 trans speedo, the ford dealer trans mechanic should have a few slick looking transmission shipping plugs for the hole (I still have one or two), or just pull the gear off the speedo shaft so it does not continue to wear.
I can add pic's to this if you want more info. Just let me know. RB
I'm still a little lost with the whole purpose of the master and slave cylinders. I thought they were only for larger transmissions. Would that mean my '78 has a similar setup since it also has a 435? I was thinking that the clutch was all manual linkage on the smaller trucks. What do the cylinders actually do?
This next question is a bit of a long shot but since np435s are just about a dime a dozen, is there a chance that one could be made to fit the diesel block, or is a T19 required for that? It would be nice if all that was required was a new bellhousing and a manual linkage along with a junkyard stick to "cure" the automatic transmission problem. Again I just think it would suck to part out any truck housing a diesel, but no one wants to spend more than what the trucks actually worth to get it moving again.
The speed sensor is either taken off the rear axle tone ring, or the transfer case. If it was off the transmission, the speedometer would not be correct in low range.
The transfer case should bolt right on with no modifications to the transmission.
jayro88
12-20-2015 07:42 PM
markkay4356
11-20-2013 12:56 PM
hivoltj
08-23-2012 10:00 PM
