FE swap
Old Nov 25, 2016 | 03:16 PM
mkolden's Avatar
mkolden
FE swap
I have a 94 f250 4x4 460 automatic. I bought it out west so the body is very nice but it has 200K miles on it and the transmission just quit going forward. I am toying around with the idea of putting an FE in it. Has anyone been down this road before? I understand that I will need an FE C6. From what limited research I have done it seems that the married C6/transfer case combos were in the 1/2 ton trucks and the highboys had divorced units. would a short FE C6 bolt up to my existing transfer case? should I use a short C6 and a divorced transfer case then make driveshafts or find a married unit.
any insight and suggestions are appreciated
Old Nov 25, 2016 | 03:36 PM
raystankewitz's Avatar
raystankewitz
As cool as that thought sounds, I would say no, don't do it.
If you have the skills to do an FE/C6 swap, you have the skills to rebuild your E4OD. There are some swaps that shouldn't be done and this is one of them.
Old Nov 25, 2016 | 08:15 PM
Lead Head's Avatar
Lead Head
Yeah I'm not sure why you'd do that. There are lots more go-fast parts these days for 385-Series engines then FEs.
Old Nov 26, 2016 | 10:48 AM
moonley's Avatar
moonley
Originally Posted by mkolden
From what limited research I have done...
If you really want to do this you'll need a LOT more research. Check out the bump and dent forums for guys swapping FE engines for fuel injected 460s and it should give you some insight; they are completely different engines and nothing will match up. Then, if you want the FE to compare to the 460's performance you will need to spend $6-$8K on go-fast parts (been there, done that).
At the end of the day this is kind of like putting a flathead in a Taurus.
Old Nov 26, 2016 | 02:35 PM
Mudsport96's Avatar
Mudsport96
​​​​​​​I have a lot of favorite internet quotes... But this is towards the top of the list
Old Nov 26, 2016 | 02:36 PM
White 97 xlt's Avatar
White 97 xlt
I'll have to say that is a good one alright!!!!!
krazytrain
Jun 28, 2015 03:34 PM
Old Ford Truck Guy
16
Jun 7, 2014 08:40 AM
jeremyd72
May 23, 2007 10:45 AM
offroad72
Aug 16, 2006 04:47 PM
