replacement thermostat housing source
Old Mar 22, 2009 | 09:17 AM
RRranch's Avatar
RRranch
Who has the best prices on replacement thermostat housings for our trucks? I need to get 4 of them now and the dealer is out of the question here. I have two that are leaking slightly on my own trucks even after rtving them and letting it dry overnight before refilling the water. Also two more trucks I need to replace the thermostat in but I'm not messing with the old housing on other peoples trucks.
Anyone know where to get new ones for a fair price?
Old Mar 22, 2009 | 12:03 PM
pjwoolw's Avatar
pjwoolw
Napa shows a BK 6051716 for about 22 dollars.
Old Mar 22, 2009 | 12:10 PM
tjbeggs's Avatar
tjbeggs
Napa has them listed at $27 list, wholesale of $20. Part number 6051716
Old Mar 22, 2009 | 09:38 PM
joe_13894's Avatar
joe_13894
Yep, what he said. It was even in stock, but then OBS/SD 7.3L diesels are about the most common vehicle on the road around here.
Old Mar 23, 2009 | 06:45 AM
tjbeggs's Avatar
tjbeggs
Dang I guess I was too slow! Well done PJ!
Old Mar 23, 2009 | 08:49 AM
RRranch's Avatar
RRranch
I had no idea Napa sold those. Thanks a lot. I'll go there.
Old Mar 23, 2009 | 03:01 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Are you talking about the neck out the top of the stat? Cuz the actual housing is the water pump.
If they leak, RTV it back on. I've had to RTV every single one I have replaced, even new. They always leak for me w/o RTV...
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Mar 24, 2009 | 12:26 AM
joe_13894's Avatar
joe_13894
That'd be my advice too. I replaced the neck and it stayed tight for about 4 months. Now it's leaking again.
Old Mar 24, 2009 | 12:30 AM
superduty4x4's Avatar
superduty4x4
Dieselsite billet T-stat neck FTW. About $35 but much less likely to leak.
Old Mar 24, 2009 | 03:20 AM
kawa's Avatar
kawa
The Billet T-stat from Dieselsite is quite a bit shorter than our OBS necks so I don't know if you have to change the upper hose or not. Perhaps someone that has installed one will jump in and clarify this.
Rog
Old Mar 24, 2009 | 06:19 AM
tjbeggs's Avatar
tjbeggs
Rog
Yep the SD neck is different. You could probably make it work with a hose extension but I am not sure I have heard of any one doing it.
Old Mar 24, 2009 | 08:25 AM
RRranch's Avatar
RRranch
I do have both of mine siliconed on right now. One took a couple months to start leaking. The other was the next day and it's just pouring out of it. I even went so far as to sandblast, repaint and straighten out the flange on it, then I siliconed it on with a new gasket. It was all a waste of time.
I am making a replacement for it btw. I have three flanges made already out of 1/2 inch thick aluminum. I am trying to figure out what to do with the pipe part. I'm thinking of pipe threading the flange and screwing in a pipe the same length or I may just weld them together. It's on the back burner till I get all the other projects in the shop done.
Old Mar 25, 2009 | 12:03 AM
superduty4x4
Rog
I thought the 94.5-95 were the short neck... my bad guys.
Old Mar 25, 2009 | 05:22 AM
tjbeggs's Avatar
tjbeggs
Short thermostat. You were on the right track just wrong part...
88_F0RD
Dec 29, 2016 03:31 PM
Dude-Ford
30
Oct 21, 2016 04:03 PM
ihf-350
Jun 12, 2015 07:09 PM
jerryparks
13
May 26, 2015 06:47 PM
crecity678
20
Feb 23, 2005 05:00 PM
