Cleaning up stock thermostat housing
Fixin to flush the truck and replace thermostat. Couldn't help but notice the stock thermostat housing looks kinda crappy. Any advice on how to clean it up good and maintain a good mess free seal after flush? I'm kinda on a budget and don't want spend money on a billet one. Also is the 203 doeselsite thermostat a placebo or does it actually do anything?
Just buy a new one.
http://www.riffraffdiesel.com/riffra...ostat-housing/
or OEM http://www.dieselorings.com/1999-200...otorcraft.html
As stated, replace it. The cost is low. You also may bend/tweak the stock one when you try to remove it.
I do not recommend going the 203* thermostat. I believe the original selling point for it was to increase your mileage. From all the feedback I have heard from it, this has not been the case. It mainly just causes oil temp issues for guys working these trucks hard.
Justin is probably right, but I plan to run the 203 until I have to take the housing off for another reason other than just to replace it with a lower temperature one. I do get 18.5 MPG unloaded and 12 MPG loaded with our 36 ft 5th wheel trailer though, so maybe the 203 helps, maybe it does not.
Honestly, I probably would have just gotten the 192 to fit the IH pump when I bought the pump 2 years ago if I had been more educated on the subject. It is what it is though...
Glad we could help out with your decisions.
Just buy a new one.
Riffraff Diesel 7.3L Billet Thermostat Housing
Justin, I have not yet monitored the oil temp. I can tell you that the fan never came on 2 weeks ago when we pulled the trailer home 1000 miles from WI to GA. When going through the mountains in TN and NC we had zero problems and the fan never came on. (knock on wood) We were getting 13 MPG with the 5th wheel through WI and Illinois, but had a pretty good tail wind, so I threw that figure out as a fluke. The 18.5 unloaded is city and highway over various terrain including north GA mountains. The 12 MPG with the 5th wheel is average from 700 miles which included plains and the mountains of eastern TN and western NC.
Last summer when we towed our 10K lbs travel trailer to Seattle from GA, the fan came on, but only during the heat of the August day when traveling across SD (Badlands area) and MT (Western mountains).
The fan never comes on when running unloaded, only when towing heavy and in hot ambient temperatures.
I have the 192 degree thermostat saved in my Amazon list for future purchase as it is the specialized short one for the IH water pump. Although, I don't plan to replace it anytime soon unless I have to drain the coolant or there is a leak of some sort that needs to be addressed. I feel that the lower oil temperature may be a good thing, but the 203 stat keeps the truck running well at a good temperature it seems.
We are taking the new to us 5th wheel out again soon, I will try to remember to monitor the oil temperature. Although, now that the air temperatures are lowering and we will be headed east where we are not in the mountains I don't see it being much more than 200 degrees.
Just for reference, we bought a 2011 Montana High Country 313RE that weighs in at just under 10K lbs dry and when we bought it the fresh water tank was full with 60 gallons weighing in at roughly 500 pounds. We now have most/all of our stuff packed in it and are ready to set out on our next trip.
