Backup Sensor
Old Mar 19, 2009 | 05:39 AM
Miguy's Avatar
Miguy
Backup Sensor
Does anyone have any info or know why the backup sensor might not work or lead my into the direction to fix it, it hasn't worked since i bought the truck.
Old Mar 19, 2009 | 06:04 AM
bismic's Avatar
bismic
Bad sensors maybe? There was a thread quite awhile ago about where you could get replacement sensors fairly cheaply. It may have even been ebay. I will look for the thread. Have you done a search (I know that some have been having problems w/ it)?
Old Mar 19, 2009 | 06:32 AM
DSMMH's Avatar
DSMMH
Same problem here
My BU system went bad about 3 months ago on my X. I found the control module and took a VOM and did a resistance check from the module connector to each sensor. All sensors read the same. So I bought a new module. Did not fix the problem. So I bought two new sensors and replaced each sensor with a new one to see if it was a bad sensor. Did not fix the problem. So after almost $300 in sensors and control module, mine is still broke. The OFF light on the dash switch is on all the time. Now that the weather is better and I have time to fix it, I just wish I could find some specific info on how the system functions or some basic troubleshooting techniques or lessons learned from people who have fixed their BU system.
Would appreciate anyone pointing us in the right direction.
DSMMH
Old Mar 19, 2009 | 08:07 AM
Miguy's Avatar
Miguy
yeah i did searching, but im not haveing much luck on finding anything on it
Old Mar 19, 2009 | 01:13 PM
Bay Boy's Avatar
Bay Boy
DSMMH
I have the same problem with my 2006 F350
Old Mar 19, 2009 | 01:58 PM
350steve's Avatar
350steve
check out this thread..Reverse Aid Sensor problem..post #8
https://www.ford-trucks.com/forums/2...ml#post1509686
Old Mar 19, 2009 | 08:21 PM
bismic's Avatar
bismic
If it is a problem with one or more sensors, the Ford part # for our trucks is (inners and outers are the same part #):
3F2Z15K859 BA
IIRC they are expensive at Ford.
They sell them on Ebay (don't know anything about the seller or the quality, but the price is good):
$7.99 each
ford backup sensors, eBay Motors items on eBay.com
Old Mar 21, 2009 | 07:54 PM
rnolloth's Avatar
rnolloth
If you can get it scanned by a good scanner you can see if theyre are any codes for each individual sensor.I had the same problem on mine and had too replace 2 sensors and i had some chaffed wiring by the trailer hitch you should check there as well.I bought my sensors on ebay for around 45 dollars.Good luck let us know.
oldpaintguy
Dec 1, 2015 03:48 PM
shelby67air
May 27, 2015 11:54 AM
rcgreg
Feb 25, 2014 02:38 PM
iron1951
Jan 27, 2014 06:46 PM
wartornwarhorse
Jul 22, 2008 12:55 PM
