Sponsored by: Real Truck
Backup Sensors
Old Dec 1, 2015 | 06:51 AM
oldpaintguy's Avatar
oldpaintguy
Backup Sensors
I have a 2011 F250 XLT. The backup sensors are not working and I get a warning whenever I put the truck into reverse. I have a backup camera so do not want sensors as well. How do I get rid of the backup sensor warning so that I do not have to see it constantly?
Old Dec 1, 2015 | 10:14 AM
r2millers's Avatar
r2millers
Try cleaning their surface.
Cleaning and coating with an Armor All or the like can foul up the receptors.
Old Dec 1, 2015 | 11:42 AM
droldsmorland's Avatar
droldsmorland
Replace the bad sensor(s). If its all of them that's usually the main harness connector has corroded. With the truck in reverse and ebrake on, you can hear the working sensors hum when you put your ear up close. No hum = bad sensor.
Old Dec 1, 2015 | 12:18 PM
wrvond's Avatar
wrvond
To permanently turn off the Rear Sensing System (RSS), start with the “System check and vehicle feature customization” section.
Press the SETUP button repeatedly to cycle the message center
Cycle through until you get to this option:
REAR PARK AID (if equipped)
-This feature sounds a warning tone to warn the driver of obstacles near the rear bumper, and functions only when R (Reverse) gear is selected.
-Press RESET to turn this feature on or off.
This will make it so you don’t have to keep turning the RSS off each time you go into reverse on your 2011 F-250.
Old Dec 1, 2015 | 03:48 PM
oldpaintguy
Thank you.
Lime Mime
Electrical Systems/Wiring
May 15, 2019 05:01 PM
rattleNsmoke
May 22, 2013 09:30 PM
dfboothe
2004 - 2008 F150
Dec 17, 2010 12:15 PM
dalman
2004 - 2008 F150
Oct 23, 2007 12:41 PM
