2002 excursion rear backup sensor not working
Old May 26, 2015 | 12:25 PM
shelby67air's Avatar
shelby67air
Checked fuses, what's the next step? Check power out back?
Thanks
Old May 26, 2015 | 12:31 PM
mecdac's Avatar
mecdac
https://www.ford-trucks.com/forums/9...ml#post9148537
Old May 26, 2015 | 02:06 PM
shelby67air
Awesome thanks I knew there was someone else with the same issue. Thanks
Old May 27, 2015 | 11:54 AM
59CRL's Avatar
59CRL
Just replaced one on mine. Took a whole 5 minutes. Back up sensor system works great now!
Do as the other thread says to check them, listen for the clicking. If no clicking the sensor needs to be replaced.
There are 2 clips on the back of the sensor at the 10 and 2 oclock positions. You can bend them out with your finger as they are very pliable as the sensor housing is made of rubber, then push the sensor through with your finger. Unplug it, plug in the new one, slide back in the housing and push the clips on the sensor so you know it is in place. Then your done... very easy.
Flynman
Jul 28, 2020 08:49 PM
timmyboy76
Oct 6, 2011 02:05 PM
Storm
May 28, 2007 10:56 PM
