ball joints
Old Mar 19, 2009 | 07:32 PM
northerndave's Avatar
northerndave
ball joints
which ones typically go bad? top or bottom?
I put the front end of my 05 F350 on stands & dried to get some movement out of the joints by grabbing the bottom & top of the tire & lifting up & down.
I got more movement out of the drivers side than the pasenger side. I couldn't watch the joints & lift up & down on the wheels at the same time so I had my boy in front of the truck watching the joints.
He said he thinks he can see the bottoms move a little. (I can feel the movement so I know there's movement)
the truck is new to me & still has a short dealer waranty on it, I think it might cover this.
I bet they'll be very excited to get to work on it for me huh?
any thoughts?
Old Mar 19, 2009 | 07:36 PM
Jimmy8541's Avatar
Jimmy8541
Since this has nothing to do with the 6.0 you might want to go to the SD section. You will get a better response over there.
Old Mar 21, 2009 | 07:56 PM
rnolloth's Avatar
rnolloth
Typically the lowers go bad first.But you should replace the uppers while its apart.
