Changing IP
Old Mar 18, 2009 | 02:37 PM
bshep's Avatar
bshep
Changing IP
Hello Guys - I just got my new IP and went to change it. How do you get at the nut on the lower passenger side? I disconnected the wires and moved any vac lines in the way....is there a special tool?
Thanks in advance
Old Mar 18, 2009 | 02:44 PM
starmilt's Avatar
starmilt
I ground down and bent a 9/16 box end and it works pretty good now it is a dedicated pump wrench.
Old Mar 18, 2009 | 02:52 PM
bshep's Avatar
bshep
Hey thanks for the idea. I'll give it a whirl. see waht angle works best.
Old Mar 18, 2009 | 03:40 PM
FORD MEGA CAB!!!'s Avatar
FORD MEGA CAB!!!
They do make a special tool. I keep mine in my door panel. Although, You can change it with a craftsman end wrench. You will spend alot of time doing it and you will use both ends of the wrench. Only a coupple degrees on each turn then you have to flip the wrench over for another round. I think I used 3 out of the 4 combinations for that end wrench. Its a pain without the right wrench but it worked for me.
bduemig
Aug 9, 2012 12:05 AM
bduemig
Jul 26, 2012 06:50 PM
1lowscort
Apr 12, 2011 09:19 PM
bignorth
Dec 7, 2006 11:34 PM
barneyfife410
Oct 30, 2006 04:19 PM
