1965 F100 vin decode
Old Mar 18, 2009 | 07:20 AM
kwlowe's Avatar
kwlowe
I am new so please bear with me if I make errors. Thanks in advance for the info. The plate on the driver’s door reads: Vin F10DK641488, WB; 129, Color: C, Model; F100, Body; E81, Trans: A, Axle; 08, Max.G.V.W.LBS; 5080, DSO; 65, 172hp@4080rpm.
Old Mar 18, 2009 | 09:47 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by kwlowe
F10DK641488, WB; 129, Color: C, Model; F100, Body; E81, Trans: A, Axle; 08, Max. G.V.W. LBS; 5000, DSO; 65, 172hp @ 4000 rpm.
Welcome to FTE
F10 = F100 2WD
D = 352 2V
K = Kansas City Assembly Plant
641488 = Assembled January 1965
129" Wheelbase
C = Special (Pure) White
F100 = F100 2WD / 5,000 lbs. GVWR
E81: E = Red Crush Vinyl & Red Ladder Pattern Woven Plastic // 81 = 81B Custom Cab
A = Ford Type 3.03 3 Speed Manual all Syncromesh Transmission
08 = Ford 9" Rear Axle / 3.50-1 / non Limited Slip / 3300 lb. Rear Axle Capacity
5,000 lbs. Gross Vehicle Weight Rating
172 Net HP @ 4,000 RPM
65 = Oklahoma City Ford District Sales Zone Office, where the original selling dealer ordered the truck from.
Old Mar 18, 2009 | 11:46 AM
kwlowe's Avatar
kwlowe
Bill,
Thank you very much.
I have been trying to figure out what color to paint, if I paint, bought for work truck but it is in great shape for 65.
can you direct me to a site that I may be able to understand (see) the above line.
it has custom cab emblems but I don't see 81B in the numbers on the plate.
is the 81 understood to be 81B(custom cab)?
If you like I have pictures of the truck on Photoshop.com
address is (strangely) kwlowe.photoshop.com thats the entire address
Thanks in advance for your knowledge,
kw
Old Mar 18, 2009 | 03:35 PM
NumberDummy
Bill,
kw
81B is the parts catalog designation for a 1961/72 Custom Cab.
AFAIK, there is no website to get the info on what crush vinyl and ladder pattern refers to.
This is what Ford calls the material and pattern.
You might try smsautofabrics.com who specializes in older vehicle upholstery. I would think they would know.
Pictures: Uh...please don't take this the wrong way, I know what these trucks look like, as I've prolly seen more of them, when they were brand new and used...than all of the FTE members combined.
Then there's the 1965 F100 in my signature....which tells you two things. 1) I bought it new in March 1965. 2) I'm older than dirt!
Old Mar 19, 2009 | 07:16 AM
kwlowe's Avatar
kwlowe
Thanks for the info.
dbgphx
Aug 15, 2013 04:40 AM
f100guy
24
Nov 21, 2011 03:39 AM
sfullmer1
Apr 17, 2011 08:24 PM
bpage33
33
Aug 8, 2010 12:46 PM
amsvage
Oct 18, 2005 01:20 PM
