Vin frame location
Old Oct 30, 2011 | 05:14 PM
f100guy's Avatar
f100guy
Vin frame location
I have a 90 f150 & would like to know where the vin is on the frame.
Old Oct 30, 2011 | 05:35 PM
SideWinder4.9l's Avatar
SideWinder4.9l
IIRC, passenger frame rail.....On the top, right in front of the firewall.....I honestly can't remember though....
Old Oct 30, 2011 | 07:14 PM
Diesel_Brad's Avatar
Diesel_Brad
Good lick. I have NEVER seen one
Old Oct 30, 2011 | 07:19 PM
SideWinder4.9l
I thought I read that on a post by Subford a looooonnnnnnnngggg time ago....Thats why I said I wasn't 100% sure...lol
Other than the Door Jamb sticker, the dash plate......That's the only places I know of 110%....Again, that was me, trying to remember something from a while back that i may have quite possibly read incorrectly....
Old Oct 31, 2011 | 10:08 AM
f100guy's Avatar
f100guy
I just got this truck and the title says it's a 90 but the cab vin says 92 and the front clip is a 92. It has the 92 interior. The reg. Sticker matches the cab. I called the previous owner and he said that it has a salvage cab and that he took it to some government place where they searched both vins. they came up clean and then they had to search the frame to find the vin that matches the title. he told me that when I get the title in my babe that the new title will have both vins. I'm sweating bullets because he probably just gave me a title for another truck. I usually check this sort of thing but not this time. On a side note, the only gauge working is the speedo. Will the 92 cluster work with a 90 wiring harness? If it doesn't then that will ease my mind and I might start trusting his story. Where can I find the vin on the motor if it's a 4.9
Old Oct 31, 2011 | 10:29 AM
SideWinder4.9l
Not 110% sure, but it SHOULD....Might have to do a bit of repinning, etc...But it should...I know the clips will work, etc...
My question is HOW is the speedo workin, I looked at a 1990 and a 1991 in the JY looking for a cluster, and they were both cable driven speedometers...
Old Oct 31, 2011 | 10:36 AM
f100guy's Avatar
f100guy
You are right, it does have the sensor on the rear end. So I got screwed probably. How do I go about getting a title for the cab?
Old Oct 31, 2011 | 10:55 AM
SideWinder4.9l
Where are you located? Here in KY, as long as the title vin, and the dash/door vin matches up...You're good...Thats all thats looked for here, is everything to line up vin # wise...
Old Oct 31, 2011 | 10:58 AM
f100guy's Avatar
f100guy
I'm in houston tx. That's the thing, the title doesn't match the vin on the cab.
Old Oct 31, 2011 | 11:07 AM
SideWinder4.9l
Hmmm....Here's to me thinkin out loud...
Call your local DMV, and "Hypothetically" ask them if you had a wrecked truck, and used that frame/title and got a used cab with a seperate vin....If you could mesh them...
OR
Ask about getting a dash vin ID tag, and a door jamb sticker made up...lol It's a shot..
If not, then ask your guy for the paperwork (If any) for the cab swap, etc...
Old Nov 1, 2011 | 07:23 AM
Diesel_Brad
That sounds like a load of CHIT to me. He should of said something upfront BEFORE you bought the truck.
As for the gauges not working, NO the 90 harness will NOT plug it to the 92 dash. The 92 spedometer is the hard thing to get working, it gets its signal from the VSS and the 90 is cable driven. I think you are right, he just sold you a 92 truck, with a 90 title
Old Nov 1, 2011 | 07:24 AM
Diesel_Brad
Got any picks of the truck?
Old Nov 1, 2011 | 07:35 AM
f100guy's Avatar
f100guy
Yes I do I will post them up later. Today I'm running the vins to make sure it's not stolen.
Old Nov 1, 2011 | 08:07 AM
SideWinder4.9l
Sounds like he got ripped off.......Sad to say it, sad to hear it...But it just takes a little bit of knowledge, and the results are STUNNING....
Old Nov 1, 2011 | 11:12 AM
f100guy's Avatar
f100guy
