Volare steering u joint?
Old Mar 15, 2009 | 01:56 PM
Fordrat's Avatar
Fordrat
I have installed a volare front end on my '53 and need to hook up the steering box to the steering column. The shaft out of the steering box measures 5/8 with 36count spline. In my search for u joints, I noticed some of the suppliers have a 5/8-36 and some say 5/8-36 chrysler. Some of them do not differ. My question, will any 5/8-36 work or do I need the one that are spacfic to chrysler? Thanks for the help.
Ricky
Old Mar 15, 2009 | 09:05 PM
jniolon's Avatar
jniolon
old and in the way
ricky,
here's what I used years ago
and here's what it looked like installed...
the polished SS is a little pricy... you can use plain old carbon steel and paint it
hope it helps
later
John
Old Mar 16, 2009 | 06:40 AM
raerjim's Avatar
raerjim
John, who's parts are these numbers?
Old Mar 16, 2009 | 07:05 AM
jniolon's Avatar
jniolon
old and in the way
borgeson
sorry I forgot that
Old Mar 16, 2009 | 09:41 AM
thomc's Avatar
thomc
The 36 spline GM and 36 spline Chrysler joints ARE DIFFERENT. I figured it out when I put a volare ifs under my 56. As best I can explain it... Chrysler left a smooth section on the shaft that would be about the equilavent of 2 or 3 splines then the 36 splines make up the rest of the diameter of the shaft. I think GM shafts are splined all the way around. That means the Chrysler splines are "finer" than the GM. I hope this makes sense.
Old Mar 19, 2009 | 08:56 AM
Fordrat's Avatar
Fordrat
Ok, thanks for the replies. jniolon, that is just about the way mine looks, except I used a column out of a '74 F100, with the shifter on the column. It has a rag joint at the bottom (I know, I might have to cut it off, but I'm trying to work with it.) Thanks
Thomc, I think I understand, and that's what I needed to know. Probably saved me about $70 bucks. Thanks.
Old Sep 12, 2012 | 09:53 PM
Streetrod.f100's Avatar
Streetrod.f100
Chrysler IFS U-joint part number?
I did not see the u-joint part number for the Chrysler IFS. Have any idea?
Old Sep 13, 2012 | 12:35 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
I used the factory Chrysler coupler on the steering gear box and used a Borgeson joint to hook it to my GM column.
Old Sep 13, 2012 | 09:53 AM
CharlieLed's Avatar
CharlieLed
Call Borgeson, they are very helpful and can tell you exactly what you need.
Old Sep 13, 2012 | 04:00 PM
53FOPAR's Avatar
53FOPAR
Got mine from Mid-Fifty. Check their catalog. They show different part numbers for the Volare and GM u-joints.
The pre-77 GM boxes were 36 spline with 13/16 inch shaft.
The Volare/Corvair/Vega were 36 spline with 5/8 inch shaft.
Mid-Fifty will also have the other end for your Ford column and a short shaft to go between the two u-joints.
I got rid of the rag joint.
The Mid-Fifty joints are real nice. Almost look like polished SS. Not sure of the brand, maybe Borgeson. Price was same or better than Borgeson web site.
kschroeder.DVM
Oct 23, 2025 12:21 AM
Optimusglen
Nov 4, 2015 08:27 AM
CharlieLed
Nov 4, 2013 09:23 AM
BACAGrizz
27
Mar 31, 2011 10:04 AM
thomc
Jun 3, 2007 07:08 PM
