2004 F150 Hitch ?
Old Mar 15, 2009 | 08:04 AM
eskew11's Avatar
eskew11
2004 F150 Hitch ?
My Factory Hitch has two holes for the Receiver. Which hole are you suppose to use,or does it even matter? Thanks
Old Mar 15, 2009 | 10:32 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
depends on your hitch length and the hole placement on it
use whichever one that gives you the proper length. doesn't really matter
Old Mar 15, 2009 | 12:20 PM
rob188's Avatar
rob188
the first hole is commonly used
Old Mar 15, 2009 | 01:42 PM
Ford Fx4's Avatar
Ford Fx4
I use the first one, second one is harder to get the pin in/out of. I also clip my brake-away cable on the pin clip and if I use the second hole I don't have enough room to clip it on it.
Old Mar 15, 2009 | 03:51 PM
mercman86's Avatar
mercman86
My draw tite hitch on my 04 has 2. A small one that the pin dosent fit in and the larger one that accepts the pin. I found out that the smaller hole is for an "anti rattle" hitch pin sold by draw tite. I saw a pic of it on their website, maybe other manufacturers are doing that also.
Old Mar 15, 2009 | 04:07 PM
rob188's Avatar
rob188
all hitch companys have this hole
Old Mar 15, 2009 | 04:27 PM
the4by4freek's Avatar
the4by4freek
??????? My original hitch had 2 holes. It cracked and failed. The dealership replaced it under warranty. The new hitch only has 1 hole. I had never seen a hitch with 2 holes until I bought my 04. All the others have only had 1. My original one cracked in 2 places.
Old Oct 18, 2013 | 08:17 AM
mark2004f150's Avatar
mark2004f150
I have a 2004 f150 xlt. My factory hitch rusted out and when I went to hook my camper up to the hitch it went to the ground. I took my truck to get a new hitch and the guys said they could not put a aftermarket hitch on because the hitch is attached to the bumper. I called the dealer and they want 700 to put another one on. I find aftermarket hitches online but I cant get it put on ????????
rbrockman
All Things Towing
May 6, 2017 03:42 PM
Vinford
All Things Towing
39
Dec 15, 2016 07:56 AM
StanleyZ
6.7L Power Stroke Diesel
Sep 26, 2016 05:25 AM
bbells
All Things Towing
Jun 26, 2016 02:59 PM
Ciras
Aug 12, 2015 09:55 PM
