390 headers for a 4*4
Old Mar 14, 2009 | 08:12 PM
Drabbit's Avatar
Drabbit
I have a 73 f100 4*4 with a 390 that needs new exhaust. Ive been looking at headers and was wondering how some of these long tubes fit in a 4*4, if they cover up the starter or any other clearance issues. Flowtech has some ceramic coated ones advertised for 4wd. Is it worth the extra money for the coated ones?
Old Mar 15, 2009 | 06:25 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
The coated headers have to be run thru heat cycling to cure the coating.. and they will go away after awhile...Unless its a race truck your not going to get any real Bennys out of running a coated header...I'd just buy a set thru Summit..a set of Hedmans..and call it good..Last I looked they were in the hood of $160
~Russ
Old Mar 15, 2009 | 07:05 AM
ihdiesel's Avatar
ihdiesel
headers
Flowtech hwaders for my F-100 74 mod. 4x4 390 eng.
www.fartssperre.no
Old Mar 15, 2009 | 09:25 AM
gearhed1971's Avatar
gearhed1971
Here's what I think about the matter https://www.ford-trucks.com/forums/7...ml#post6592403
Old Mar 15, 2009 | 11:51 AM
Drabbit's Avatar
Drabbit
so can you still get to the starter after they are installed. Is the gain in performance really worth all of the hassle, doesnt sound like a lot of fun.
Old Mar 15, 2009 | 12:27 PM
ihdiesel's Avatar
ihdiesel
390 sound
link to test drive . 390 +headers + 2 x 2,5 inch ex.
YouTube - Climbing Part #2
YouTube - ford fe-390 test drive
Old Mar 16, 2009 | 01:22 PM
bertha66's Avatar
bertha66
I've run headers on my 66 F100 4x4 now for over 25 years, no problem with the starter or leaking. IMHO they were well worth putting on.
Old Mar 16, 2009 | 03:42 PM
gearhed1971
Not so much a problem with the starter,more the pass. side motor mount.Its run right through the 2nd and 3rd primary.
Old Mar 16, 2009 | 06:15 PM
Drabbit's Avatar
Drabbit
So even if i buy the headers that are supposed to be made for a 4wd am i still likely to run into the motor mount or anything else? Thanks for the replies.
Old Mar 16, 2009 | 07:24 PM
gearhed1971
Guess it depends on what headers you get,maybe that's where the big bucks come in
Old Mar 17, 2009 | 12:25 AM
fordeverpower's Avatar
fordeverpower
i have hedman 89180? and the 4th primary was very close with the starter, i made some clearence.
Old Mar 17, 2009 | 09:51 AM
77 Bronco's Avatar
77 Bronco
I just installed a set of Sanderson FF427 ceramic coated headers on my '68 F-100. Worked out great. Very great quality. They are a little close. The only issue was my trans cooler lines (mine are a little bent up anyways) and you can't get the starter out without taking the passenger side header out. The collector flange is parellel with the oil pan flange. My truck is a 2WD though.
Old Mar 17, 2009 | 10:10 AM
RapidRuss's Avatar
RapidRuss
well I have run Full length hedmans on my 70 F250 2Wd... Since 1974 on my 395"er..and even tho its a tight squeeze for the starter...after a few starters being burnt out from heat saturation..I finally got a starter that lasted some 30 years and is still in the truck today..and its a reman starter From Chiefs out on the west coast..
I have never had to loosen up the Pass side to drop the starter..It just takes a little wiggle room and a tilt and it drops right out... I have only used 2 sets of gaskets with those headers..once when first installed, and the second time when I installed the motor after the rebuild... and I dont use heat wrap on them...and they havent ever rusted even being back here in Southern Va for 17 years.. But i keep em clean also... JMO.
Old Mar 17, 2009 | 03:06 PM
bertha66's Avatar
bertha66
The headers that are on my 66 4x4, the passenger side came in 3 pieces and go around the motor mount.
Old Mar 17, 2009 | 03:32 PM
gearhed1971
Yes,two wheel drive is different than four wheel drive.The headers I got were only welded on two primaries on the passenger side,I guess for ease of installation.I still had to take a inch and a half notch out of the perch though.
