Shock Install
Old Mar 13, 2009 | 02:50 AM
BatteriesNotINCL's Avatar
BatteriesNotINCL
Shock Install
Can you install shocks upside down in the rear? I've seen trucks with both the boot on bottom and top. TIA
Old Mar 13, 2009 | 03:14 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
not sure if you can on these trucks.
Rancho/Bilstein say their shocks are designed for use upwards mounted...but the Jeep community has been proving for years that shocks will work just fine upside down
btw, why?
Old Mar 13, 2009 | 04:25 AM
slparry's Avatar
slparry
I had called Bilstein a few years ago about this. At the time they told me it made no difference which way they were mounted..
Old Mar 13, 2009 | 01:34 PM
BatteriesNotINCL
btw, why?
I mounted them the same as the shock came off....boot on bottom. A few of my fellow truck buddies said that it was wrong and we got into a debate... just wanted to make sure I wasn't making an *** of myself.
Old Mar 13, 2009 | 06:24 PM
ChargersFanInCO's Avatar
ChargersFanInCO
Why would you? Seriously? I'm curious.
Old Mar 13, 2009 | 08:29 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
like I said, in Jeeps, you have to mount the rear shocks upside down on the TJ's...maybe the YJ as well. There isn't enough room by the upper mount for the shock body to clear, so you mount them upside down so the skinny part is up there
otherwise, I can't think of any reason to mount the "body" on the bottom...aka upside-down
Old Mar 14, 2009 | 11:22 AM
ChargersFanInCO
I was just wondering...It didn't think it would change anything upside down.
Old Mar 15, 2009 | 02:07 AM
dfishrmn88's Avatar
dfishrmn88
I would think you could. I installed some Monroe Reflex on my '05 rears and it could have been easily done upside down but why woulld you want to. Even with a boot with the larger side down I would think it allows an area for dirt to collect and possibly work its way into the shock. Just a thought.
timbrady
Jan 22, 2014 08:08 AM
fordguy62
Mar 25, 2013 11:23 PM
pearsonrb
2004 - 2008 F150
Jan 27, 2010 04:36 AM
dfishrmn88
2004 - 2008 F150
Feb 4, 2008 06:33 PM
caddywhompus
1978 - 1996 Big Bronco
Jan 12, 2004 08:38 PM
