Installing Shocks
Old Jan 21, 2014 | 11:12 AM
timbrady's Avatar
timbrady
Installing Shocks
Who has put on shocks without a lift? Is it possible? Terrible job or not so bad?
Thanks!!
Old Jan 21, 2014 | 11:21 AM
BLADE35's Avatar
BLADE35
Mines got a Lift so was easy didn't have to remove tires for fronts
But a STock truck I wouldn't think would be too Bad might just have to remove front tires to get at it
Id go for it SHocks are easiest thing you could do about
Old Jan 21, 2014 | 11:28 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
It's easy. Kroil penetrating oil and a gear wrench for the top of the front shocks, then regular sockets for the other 6 fasteners. I do the tops of the fronts first, then the bottom of the fronts so I can be underneath when I lower them out and not trying to hold them up for the last bit of the top shock nut.
One hour AND one six pack, because it's the perfect excuse.
Old Jan 21, 2014 | 12:23 PM
timbrady's Avatar
timbrady
I'm at stock 4WD height, so it's not terribly low to the ground. So, do you need to jack the front and remove a tire or can you just cut the wheel and get them out with the wheels on the ground?
Old Jan 21, 2014 | 12:38 PM
texastech_diesel
Token Redneck
I don't recall removing anything to change the shocks out, or lifting the truck. But I'm relatively compact and can slide underneath the front axle while on a creeper, so if you have trouble fitting underneath or crawling on the ground it might be better to pull a wheel. But it's not required to, it should work without removing anything.
Old Jan 21, 2014 | 01:23 PM
clevelandtundra's Avatar
clevelandtundra
How'd you guys torque the top nut to the right lb/ft on the front shocks? Anyone got torque specs on the rear shocks?
Old Jan 21, 2014 | 01:33 PM
texastech_diesel
Token Redneck
Correct way would be a crowsfoot or extender on a torque wrench if you can't set a socket on it. I use the German "gootuntite" spec for it.
Rear:
Old Jan 21, 2014 | 01:35 PM
clevelandtundra
Rear:
lol thats what I thought, thanks bro.
Old Jan 21, 2014 | 02:50 PM
MisterCMK's Avatar
MisterCMK
Torque wrench for shocks? Naaahhh
Just crawl under there and do it. You don't even have to lift up the truck or put it up on ramps. A ratcheting wrench works well for the front upper nuts.
Old Jan 21, 2014 | 04:31 PM
acf6's Avatar
acf6
Yea no need for a lift or anything...the shocks dont support any weight. Unbolt old ones, re bolt in new ones. Should be 5-10 mins tops per shock, definitely not a 6 pack job but you can make changing windshield wipers a 6 pack job too
Old Jan 21, 2014 | 04:39 PM
Mich6.0's Avatar
Mich6.0
air gun works great. cut the wheels or remove if you have a warm garage or live in warm weather
Old Jan 21, 2014 | 06:19 PM
texastech_diesel
Token Redneck
It's an EXCUSE, get it?
Old Jan 21, 2014 | 06:21 PM
acf6's Avatar
acf6
do you see what i did there?
Old Jan 21, 2014 | 08:15 PM
texastech_diesel
Token Redneck
I might have noticed......but then again I might have changed out my wife's windshield wipers today and have already utilized the requisite consumable tools It's the damn nice 70* weather we're having here that makes going into the garage so enjoyable! Even if her stupid Jeep has three sizes of wiper blades that I'm too stupid to measure before I headed to Wal Mart for my parts and supplies.
Old Jan 21, 2014 | 08:25 PM
BLADE35's Avatar
BLADE35
Well the Last Blinker Fluid Change I did Was a Case a Beer plus 5th of Captain morgan with a Few Bong Hits along the Way
All I can say for SURE is it was Smooth Sailing LMAO
