Sponsored by: Real Truck
Bed Bolts Size?
Old Oct 18, 2007 | 04:56 PM
VQ2Fast4U's Avatar
VQ2Fast4U
Bed Bolts Size?
Anyone know what torx bit I need to remove the bolts in my bed?
Thanks.
Old Oct 19, 2007 | 12:09 PM
VQ2Fast4U's Avatar
VQ2Fast4U
Bump..............
Old Oct 19, 2007 | 12:16 PM
dkf's Avatar
dkf
T50
Thread size is M14X2.0
If you plan on removing them good luck.
I just removed my bolts had to grind the heads off of three bolts. I cut the bolts and keep nut clip from underneath to remove them. (PITA) There are at least 3 different size bolts for the bed and will run $12-$15 depending on size at the stealership.
The bolts are a rip-off and a major screw-up by Ford IMO. Had to vent.
Old Oct 19, 2007 | 12:45 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Use lots of PB Blaster a day or two before you try to remove them...get to as many as you can from uder the truck.....This worked well for me....didn't strip a one.
petei
Sep 18, 2017 07:50 PM
jacobn936
Apr 16, 2017 07:33 PM
99SuperDuty2017
Nov 16, 2016 06:46 PM
BlueBeauty
Jun 23, 2016 05:55 PM
Basham11
Dec 10, 2015 09:30 AM
