Sponsored by: Kumho
shocks
Old Mar 14, 2009 | 01:16 PM
R031Kona's Avatar
R031Kona
Good, what did you go with?, Bilstein's ?
Old Mar 14, 2009 | 07:09 PM
spinella's Avatar
spinella
yes. i ordered them from shockwarehouse. you cant beat that price. i should receive them tuesday-wensday.
Old Mar 14, 2009 | 08:10 PM
rootbeerford's Avatar
rootbeerford
I'll be looking forward to a review.
Old Mar 24, 2009 | 07:19 PM
spinella's Avatar
spinella
i received my shocks today. i installed them...took about 40 minutes. so far they feel good. that being said the shocks that came out would compress and not rebound and you could extend them and they would stay in that position. shockwarehouse was good to deal with and i would buy from them again.
btw all my shocks were installed boot down. steel b ushing in the lower mount. that correct...right?
Old Mar 25, 2009 | 10:13 AM
ShockGuys's Avatar
ShockGuys
The front should be boot down - Bilstein shocks and struts for cars and trucks - Shockwarehouse.com.
The rears should not - Bilstein shocks and struts for cars and trucks - Shockwarehouse.com.
Old Mar 25, 2009 | 09:39 PM
spinella's Avatar
spinella
so are the stickers upside down on the rears? i installed them with the metal bushings in the same location as the ones i took out. also does it make sense that i was able to compress the rears with my hands but the fronts were rock hard. i needed a floor jack to install the fronts. thanks.
-ed
Old Mar 25, 2009 | 10:21 PM
R031Kona's Avatar
R031Kona
Originally Posted by ShockGuys
So how would you recommend installing Trailmaster shocks (correct for 4" lift ) in a 91 Ranger with a 4" lift?
Old Mar 26, 2009 | 11:10 AM
ShockGuys's Avatar
ShockGuys
-ed
Ed, that is correct. I have not heard of being able to compress the shocks by hands. How are they reacting when you drive? Do they feel soft?
I'm not familiar completely with Trailmaster's. We are a distributor of Bilstein's, Edlebrock, KYB, Monroe and Rancho shocks and Monroe brake pads.
Old Mar 26, 2009 | 06:01 PM
spinella's Avatar
spinella
its hard to tell because the old ones were junk. i definitly can compress them by hand. when they were delivered one of the plastic bands was off the shock so the shock pushed through the bilstein box and the outer brown box. i thought nothing of it and installed them. the fronts were rock hard.
Old Mar 27, 2009 | 01:00 AM
R031Kona's Avatar
R031Kona
I have had Gabriel's, Monroe's, Trailmaster and maybe I have huge biceps but I have always been able to compress them by hand.
Old Mar 27, 2009 | 03:23 PM
ShockGuys's Avatar
ShockGuys
The straps are intended to keep the shock from expanding. The delivery person must have really did a number for that to happen.
Also, some shocks are harder to compress than others. The fronts will be harder because of the weight they are bearing (engine). Although you may carry some weight on the rear they should be 'softer' to some extent.
Old Mar 27, 2009 | 06:56 PM
spinella's Avatar
spinella
i called bilstein today. there tech guy said compressing the rears is normal and the front should be rock hard. he also said boot down on front and the rears can go either way. i'm keeping mine boot down so the metal sleeves are in the same position as the shocks that came out.(bottom mounts) if anyone has any ques heres there phone # 858-386-5900 just ask for tech.
Old Mar 30, 2009 | 09:34 AM
  #28
ShockGuys's Avatar
ShockGuys
Bilstein
Ed,
That makes total sense about the shock compression. Interesting about the rears can go either way though (boot up or down). They've never specified this, nor does their manuals state they can be flip flopped. Thanks for posting.
Old Mar 30, 2009 | 05:58 PM
  #29
Bill De's Avatar
Bill De
Thanks guy's!
Thanks guys for all the info in this post. I got on to read the ball joint replacement thread, and noticed this topic. Anyway, I ordered the Bilstein BST,s for my 2001 F250 Super Duty 4X4, got the 3 for 1 price and the pro-mo discount.
Bill
lewis racing
Sep 11, 2014 07:57 AM
mdwilli
Apr 21, 2009 10:25 PM
godblessmud
Offroad & 4x4
Feb 3, 2008 07:26 PM
jimb206
Sep 15, 2005 07:19 PM
94' Ford
Jul 12, 2004 05:49 PM
