when i had my 88 i took out the two heater grills in the vents on each side of the stock cluster. i made metal inserts for them and painted them black i put a gage in each one. now that i have a 96 body i went with a pillar mount
Isspro pyrometer and boost gauge in a pillar pod.
Volt, oil pressure and coolant temp in an uderdash pod, turned over and mounted on top of the dash radio speaker hole.
Oil temp under the dash, looking for a new home since it is so hard to see.
Pyro,boost, trans. temp(manual) on a-pillar (stolen out of my PowerStroke=FREE!)
Rearend temp on top of dash soon to be joined by a REAL oil pressure gauge and maybe an oil temp. gauge.
Currently, stock dash setup plus a VDO pyrometer mounted (already there when I bought it) on the top right side of the dash pad above the instrument cluster.
I plan to add oil, temp, voltage and boost gauges sometime in the near future.
