I put a "T" on the map line as well. I raan I think a 1/4 vacume line into the cab and installed the gauge. I do not like the looks of the white boost type line so thats why I used the black vaccume line. Just my $.02
I routed my boost line through the diamond shaped plastic access panel thingy (I think it's for the clutch setup on manuals) and on to the gauge. Sorry no pics of that but here's a shot of the tee:
I covered the white boost line with black wire loom.
One last question adn then ill hang it up. Where did you guys hook the power cables up to make the lights come on with the headlights. Dont want to go splicing wires without a little heads up.
Thanks Pat that looks like it wil be a big help for the setup, guess ill go get me a trans gauge to since it shows how to do that one as well and will be ordering a pyro one soon.
Would it be better to put the pyro sensor behind the turbo on the Downpipe to have an exhaust temp or would that be an in accurate reading.
The pyro should go before the turbo. Either in the manifold or the up pipe. Mine is in the up pipe. If you have problems an up pipe is cheaper and easier to replace than a manifold. I will be doing a pre turbo and a post turbo comparison soon. I'll post my findings then.
I agree with Pat.. go figure... but I did tap my manifold. It was a real easy tap.. talk to us before you do it though. I wouldnt want you to go to deep with the tap.
Preturbo for the pyro! Just dip the drill bit into some wheel bearing grease before you drill to catch the shavings. Personally, those shaving are so small that they will blow right through the turbo without any issues though.
