Lower not Higher
Old Mar 11, 2009 | 08:48 PM
Monsta's Avatar
Monsta
Sit. Stay.
Yup...sho-nuf.
Old Mar 22, 2009 | 10:21 PM
gixermann's Avatar
gixermann
Originally Posted by soutthpaw
Not sure I understand your question. you just need to buy spring perches from a 4x4 shop and weld them onto the bottom of the axle. they need to be parallel with the existing perches as it will affect your caster angle for the alignment. then the U bolts and mounting plate get inverted and reinstalled with axle on top of the spring
Ok I crawled under to look thing over before ordering the perches like you hade mentioned..Huge problem..It looks like the boltin point for the sway bar would be in the way 1, and 2 on the drivers side the mounting bracket for the leafs are at and angle to make room for the differential..so no flat sufaces for a good mounting point. Any body out there with 2x4 I would greatly appreciate as many detailed pics as possible of the front suspension setup so that I can do a comparison..thanx
dalco1406
Nov 10, 2013 10:38 PM
bman50
2004 - 2008 F150
Jan 12, 2010 06:58 AM
fanman2
2004 - 2008 F150
33
May 3, 2004 08:16 AM
ghittner
Jul 29, 2003 09:45 PM
