Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Why not use PVC?
Old Jan 19, 2010 | 10:20 AM
12ozd's Avatar
12ozd
Originally Posted by B1942
Maybe I'm lucky. I plumbed my compresser in the garage with schedule 40 PVC about 30 years ago, so far no problems. Granted it only puts out 120 pounds but it is the best investment, tool wise, I ever made. Maybe pvc was better quality 30 years ago?
Same here,although I will agree it's probably not the best option.
Old Jan 19, 2010 | 09:14 PM
*2fords*'s Avatar
*2fords*
I ran schedual 40 all through out my shop, and with in the first 2 years it blew out 3 times. There were peices everywhere. Luckly the compresser is outside my shop and that's where all the breaks happened.
Old Feb 13, 2010 | 11:08 AM
monckywrench's Avatar
monckywrench
I just run decent quality air hose instead of piping. Less work, easy to alter or repair, lasts a long time.
Old Feb 13, 2010 | 12:08 PM
LMS Residential's Avatar
LMS Residential
1) PVC is not the first choice for high pressure air or gas.
2) Schedule 80 PVC is by far the only piping I would use if I HAD to run plastic air lines.
Most importantly:
3) The fittings that failed were vent fittings, designed to withstand atmospheric pressure only. Note the sharp turns, they are supposed to be used for venting plumbing fixtures to the atmosphere, nothing more.
Thank God no one was killed or seriously injured. Another bit of advice for those of you using PVC air lines would be to bleed down the system when not in use and install a pressure relief set to a few lbs over the max pressure you use in your shop. Might just save an accident.
Old Feb 13, 2010 | 04:58 PM
Aftrmidnite's Avatar
Aftrmidnite
Why don't you guys use Pex, with the crimp connectors? Freeze proof, Corrision proof, dent resistant, doesn't transmit vibrations, and easy to work with.
Old Feb 13, 2010 | 06:06 PM
tjc transport's Avatar
tjc transport
i ain't rite
is PEX pressure rated to 200+ lbs??
95stepside's Avatar
95stepside
where i work all the air lines are black gas line and the only problems weve ever had are welds leaking. why they decided to weld it to the mounts ill never figure out. maybe cause its a welding shop and its cheaper than clamps? who knows lol
Old Feb 13, 2010 | 07:18 PM
Aftrmidnite
PEX Material at 180º *
Silane PEX 375 psig burst
Peroxide/Engel PEX 305 psig burst
Radiation/E-beam PEX 315 psig burst
*Slightly higher burst at 73.4º F
Go too iPlumb.tv - PEX Plumbing and Radiant Heating Systems and contact them on application.
Shibbydog
1997 - 2003 F150
Jan 7, 2013 06:57 AM
Milwaukee1979F150
Modular V10 (6.8l)
Sep 14, 2009 05:32 AM
anah go karts
1997 - 2003 F150
Mar 28, 2009 11:58 PM
96_4wdr
Aerostar
Apr 6, 2006 05:38 AM
m350
Garage & Workshop
26
Nov 30, 2003 11:22 PM
