Sponsored by: Auxito
pvc valve
Old Mar 26, 2009 | 06:11 PM
anah go karts's Avatar
anah go karts
Question pvc valve
Hi
I have a 2001 f150 supercrew 4x4 5.4. using about a qt and a half in 700 miles.i did a vacum test on the line to the pvc valve it was about 23 lbs and should i be able to see threw my pvc valve there is no way for it to close should it be that way
Old Mar 26, 2009 | 06:29 PM
n5926g's Avatar
n5926g
I dont know about the suction issue,but you should NOT be able to see through it.This is basically a 1 way valve,that opens when a preset amount of suction is applied.In the "old school" we just shook them. If they rattled,they were fine,if not it got replaced.........
Old Mar 26, 2009 | 06:32 PM
Sooper-Doodie's Avatar
Sooper-Doodie
That "valve" is most likely under the valve cover now. You need to get it out as it may cause damage to the engine.
Old Mar 26, 2009 | 06:34 PM
anah go karts
thats what i always did ....but you can blow or suck on this 1 no difference either way and you can look riight threw it there is still a thing in the middle of it but NO resistants to air flow either way
Old Mar 26, 2009 | 07:29 PM
n5926g's Avatar
n5926g
Should be cheap...replace it...
Old Mar 27, 2009 | 06:37 PM
LxMan1's Avatar
LxMan1
Get one from the dealer, they work best!!
Old Mar 28, 2009 | 12:45 PM
anah go karts
got 1 from car quest for now .....til i can get to the dealer thanks for all your help
Old Mar 28, 2009 | 11:58 PM
LxMan1's Avatar
LxMan1
That's better than a broken one. Seems that the Motorcraft units are better calibrated for the proper amount of airflow.
abyars111
Oct 31, 2014 04:10 PM
Breas2
1983 - 2012 Ranger & B-Series
Feb 26, 2010 12:35 PM
Milwaukee1979F150
Modular V10 (6.8l)
Sep 14, 2009 05:32 AM
cctough
2004 - 2008 F150
Jul 17, 2009 05:50 AM
northernowl
1997 - 2003 F150
15
Dec 29, 2006 09:00 PM
