Aerostar Ford Aerostar
PCV oil separator
Old Apr 5, 2006 | 02:09 PM
96_4wdr's Avatar
96_4wdr
PCV oil separator
oil separation filter for PVC line to help keep the MAF, TB, plenum runners and intake valves clean and engine at peak performance
install with brass pipe to tubing push on nipples to fit size of PVC line
really has helped my Aero 4L on long hot summer trips where oil puts out more voilitiles and more blowby into crankcase
have one on all the rigs...the PVC feed tube is close to the MAF and before the TB on my 4L
this is the lowest cost and easiest to install/service that I have found yet
http://www.homedepot.com/prel80/HDUS...prod_id=169654
Old Apr 5, 2006 | 08:08 PM
ken1mod's Avatar
ken1mod
These units are used in aircraft engine crankcase vents quite often. I think they are a great idea. Some time ago, I posted the installation of a crankcase vent filter to do the same thing.
Ford's putting the vent line so close to the maf sensor was really stupid.
Ken
Old Apr 5, 2006 | 08:38 PM
Torque1st's Avatar
Torque1st
Posting Legend
Do you mean the PCV as in Positive Crankcase Ventilation line???
PVC is plastic...
Old Apr 5, 2006 | 09:52 PM
96_4wdr's Avatar
96_4wdr
cuodl eb could be
i've always been a dyslepsic tpysti tipyst typist
yuo egt teh diea wihgt?
PVC is plastic...
Old Apr 6, 2006 | 01:27 AM
Torque1st's Avatar
Torque1st
Posting Legend
If you have problems with blowby getting into the sensors and intake it may just help to replace your PCV valve. They do wear out and need to be replaced annually. Just because they rattle does not mean they are any good. Compare the position of the pintle valve on your old one with a new one by turning them upside down and look at the intake side. You can see if the spring has "sagged" any. If you still have problems replace the valve with one of the same configuration but for a larger displacement engine. The dealership may even have a part number for a high flow valve for your engine.
Old Apr 6, 2006 | 05:38 AM
96_4wdr's Avatar
96_4wdr
isn't that what the purpose of the PCV is? To remove combustion byproducts, fuel dilution and other volitiles that boil off from the oil?
Ford engine engineering placed the intake air feed point of PCV gases in the wrong point in many of their designs, should be as close to intake valves as possible, not next to MAF and prior to TB
May be one of the many reasons they can not longer build an engine Americans will buy or trust for 200k miles+....
Duck Hunter81
Jan 5, 2010 04:26 AM
Diesel_Brad
Aug 11, 2009 07:56 PM
Georgia 66 f100
Garage & Workshop
15
Dec 6, 2004 09:15 PM
F0XR0D
Garage & Workshop
19
Jun 21, 2004 03:54 PM
alanscott
1978 - 1996 Big Bronco
Oct 2, 2003 11:42 AM
