Boost, EBP, Mileage
Old Mar 15, 2009 | 10:58 AM
aldridgec's Avatar
aldridgec
Update:
Wondering if I have a temperature issue. I double confirmed no boost or drive pressure leaks with a smoke machine. Now that it has warmed up, I'm noticing power is up and don't seem to be using fuel at the same rate but haven't fuel up yet to have a calculation. Seems pretty fast to stop using winter fuel, as it suddenly got warmer I think there is more to the temperature.
Old Mar 15, 2009 | 11:09 AM
rebelchevy02's Avatar
rebelchevy02
I notice with my truck, the physically colder it is outside, (IE less then 20 degrees) the worse my fuel mileage gets. Alot of that is highway, and cruise set at 60 mph. My boss joked with me about that, but with air being more dense at colder temperatures, theres a possibility with our un aerodynamic body, that the wind resistance it takes to push our trucks through the colder, denser air, could very well have a negative affect on our mpgs.
Old Mar 15, 2009 | 02:08 PM
nlemerise's Avatar
nlemerise
I stole the image below from this document.
Old Mar 15, 2009 | 03:02 PM
MADVAN's Avatar
MADVAN
Chris
Check your running EOT.
The PSD seems to like 200*f for good mpg.
To cold of an eot can stem from a bad coolant T-stat.
Bill
Old Mar 16, 2009 | 03:08 PM
aldridgec's Avatar
aldridgec
iirc my EOT was running around 185 but I will have to check it again. May be a moot issue considering it is warming up, but I am going to look into it further.
Old Mar 16, 2009 | 03:18 PM
MADVAN's Avatar
MADVAN
Its why i say its running to cold.
Most winters i even have to also block off the rad to get the temps up.
Depends on how the truck is being used. (no/light loads = to cold)
Bill
Tugly
223
Aug 18, 2019 07:36 AM
wannabe7.3
Feb 25, 2015 02:15 PM
Y2KW57
Jul 28, 2014 04:16 PM
johnny williams
Aug 26, 2013 06:15 AM
superdutymanfx4
May 19, 2013 09:58 PM
