Blue Smoke on Deceleration
Old Mar 5, 2009 | 06:46 PM
royzell's Avatar
royzell
That may be a bit misleading as the truck never moved. Yesterday I looked at a '90 7.3 2WD with a toasted E40D. The incentive was the Banks Turbo.
It had been sitting a long time, we finally started it with a jump from a new Powerstroke (yeesh...)
Anyhow, black smoke on revving (OK), but lots .. clouds.. of blue when we let off.
What does the blue mean ?
The guy wanted too much, if he wakes up and calls back I may consider it.
Old Mar 5, 2009 | 07:02 PM
David85's Avatar
David85
Might not mean anything other than sitting for too long. Its hard to say if something is really wrong or it just needs to be driven at higher EGTs to clear its throat after sitting for too long. Might also be timing off. Guys often like to go overboard with advancing the timing when they hear that you get *more power* and take it to an extreme.
I know what you mean about wanting too much for IDI or IDI turbo related stuff. On the island here guys seem to think they're made of gold or something.
Old Mar 5, 2009 | 09:45 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Sitting to long, CDR needs cleaned, timing all could be the problem.
Valve stem seals are not out of the question either.
Old Mar 7, 2012 | 02:07 PM
maverick1701's Avatar
maverick1701
holy zombie thread batman!
have you had any updates on your post?
My new truck does the same thing.
If you are driving and totally let off the accelerator, there is NO smoke. If you just pull back the accelerator to (for example lets say half throttle) half throttle then I get white-ish, gray-ish, blue-ish smoke for a second or two then it goes away. The smoke also goes away if I give it more throttle after releasing.
I just drove it from Austin, TX to dallas, TX and my oil level has not changed enough to show on the dipstick.
Im off to do a search on the CDR valve that was mentioned above.
Old Mar 7, 2012 | 03:34 PM
whiteboyslo's Avatar
whiteboyslo
This is a thread I started on return lines, but we talked a little about CDR valves as well:
https://www.ford-trucks.com/forums/1...tructions.html
Hope this helps. It's a really easy job. 2 bolts and a hose clamp or two.
Mike
6.9dustin
Jun 24, 2017 06:53 PM
CanMoose
Mar 26, 2017 10:14 PM
BrendanFitz
Jan 1, 2016 11:32 PM
sand1
Feb 9, 2013 08:22 PM
rickatic
Jun 18, 2010 10:11 PM
