traction bar styles
Old Apr 11, 2009 | 09:05 AM
  #31
84-250's Avatar
84-250
I keep looking at pictures of installs on a few sites but there is not a rhyme or reason to where the axle bracket points. I've seen straight down, 45* forward, and 90* straight forward.
Opinions.
Old Apr 12, 2009 | 03:54 PM
  #32
RubberDuck's Avatar
RubberDuck
The brackets on the axle need to be pointing straight down. if you mount them on the front, they will just pivot up like normal and be useless. I believe if you take a look at my thread "The Truck Thread" somewhere in the later pages you can see pics of my ladder bars. If you can't find them, let me know.
Old Apr 12, 2009 | 04:45 PM
  #33
84-250's Avatar
84-250
How can procomp get away with the bolton brackets which go between the axle perch and block? The mounting point for the trac bar would be slightly above the centerpoint of the axle tube. I saw your pics.
Old Apr 12, 2009 | 08:05 PM
  #34
tjbeggs's Avatar
tjbeggs
I have wondered the same thing!
Old Apr 12, 2009 | 10:31 PM
  #35
Tom S's Avatar
Tom S
I think the theory is the that the push is on the traction bar and the pull is on the spring with the brackets in the front.
Tom
Old Apr 12, 2009 | 11:14 PM
  #36
RubberDuck's Avatar
RubberDuck
We've tried the pull theory on our mud trucks. One link above the axle, still mounted to the frame the same way. Didn't work at all. Still had axle wrap all day long. But I think you are right Tom.
Old Apr 13, 2009 | 04:27 PM
  #37
84-250's Avatar
84-250
RubberDuck: I saw your pictures of your traction bars, I noticed you have square tubing instead of round. Is square stronger than round if they were the same size and thickness? What thickness is your front brackets, looks like 3/16". Of course sqaure tubing would be easier to notch for the bushings. Looks like you used 2x2 tubing, right.
Old Apr 13, 2009 | 06:57 PM
  #38
RubberDuck's Avatar
RubberDuck
I used 1 1/2" X 3" 11 gauge. And taper it to the bushing pipe. I used 1 1/2 pipe for my bushing ends. Not sure on the thickness of my front mount, but I need to gusset it, I know they flex. As far as stronger, not sure, but I just like to be different.
Old Apr 13, 2009 | 10:20 PM
  #39
fishmanndotcom's Avatar
fishmanndotcom
i was just over on pirate and re-stumbled across the article where i got all of my ideas, just to add some more info for ya
http://www.pirate4x4.com/tech/billav...ntiwrapbar.htm
-cutts-
GaTreeStumper
Feb 12, 2016 10:22 PM
RollalongCC
Jun 24, 2013 09:51 PM
boo-yaa138
May 9, 2013 07:30 PM
bigjp
Offroad & 4x4
Jan 5, 2010 02:39 PM
