Ive ran the pro comp stage II's before on one of my gas monsters and they still had good articulation. That was with it mounted right at the leaf perch on the rear housing. then they hard mount to the frame and they come with poly bushings. That was also while running a 9" lift, a locker, and 40's. Im intending on putting another set of em on this truck. The only drawback I found was like Coon said. They were long enough about 5.5' so they caused a possible high center issue with the low angle. But they at least sat high enough on the axle to not be hit by being below the axle.
That's some pretty welding Jason. LOL..................I had to.
LOL, i knew someone was going to say something... and rightfully so. it looks absolutely horrendous. i honestly dont know why it looks so bad. i can tell you this though, i have not been what most people would call easy on her and it has held up fine so far!. if i ever get a chance i am going to pull it off and redo them, but they are not on my top priority list.
heck, i pulled against a dodge 3500 dually with a CM custom metal flatbed a couple of weekends ago. he had the disadvantage since we were on dirt but i still couldnt pull him. my front end got to hopping during all this and actually separated my driveshaft which i am in the process of lengthening. and it held up to that! i had NO wrap in the back.
so ya, go make fun of my globber welds but at the end of the day they are still holding strong!
does anyone remember that guy that had that website of the PSD he re-finished everything on? i know he did a write up on TSC traction bars that looked pretty nice.
Mitch
what do you guy use to weld the brackets to the axle, ampreage? Im thinking about greaseable poly bushings on both ends at the exact angle as the driveshaft.
Im using poly mainly cause of cost. Since im not using the procomp brackets, like in the pic, there wont be a misalignment between the brackets that would require something like a johnny joint setup.
Im buying a ready made bracket to attach to the axle.
Im going to make the bracket on the frame side because of the offset toward the outside of the frame. How many amps do you think i need to get proper penetration?
