Modular V10 (6.8l)
Bye bye, JBAs.....
Old Mar 11, 2009 | 06:39 PM
Sooper-Doodie's Avatar
Sooper-Doodie
If you constantly get any header wet it's not going to last. Ebay headers are no different. Before I installed them, the only difference noted was the crazy dome looking thing in the collector of the JBAs, other than that, material and construction is about the same.
Old Mar 12, 2009 | 06:09 PM
meanv10's Avatar
meanv10
Originally Posted by Krewat
They came that way right out of the box.
They have some surface rust now, just like you would expect from a decent grade of stainless (better than the stock exhaust system that's "stainless"), but that's after almost 2 years on the truck, and they salt the roads around here a lot in the winter.
They still do have some shine left though...
they are different grades of stainless, your eBay headers are probably an 304, austenitic stainless, or your basic 18-8. The exhaust manifolds are some type of cast ferritic stainless steel that don't have the same amount of chrome with high carbon that ties up even more of the free chrome, and sulfur for machinability.
The actual exhaust pipe from the manifold back is also a ferritic stainless 409 I think, that's why you dont need to replace the exhaust on your cars every 10 years like you would if you had a carbon steel exhaust. Most people think that Stainless steel has to be shiny and never rust.
Old Mar 13, 2009 | 11:21 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
If anything, PM TeamMudd to contribute to this thread if possible, instead of holding off-forum discussions about anything that we as a community might find interesting.
I've beaten my truck up pretty good. I've jerked and pulled stumps, drag-raced, full load for extended periods of time, you name it.
The ebays are still holding up. As long as you have a good exhaust system, and it's not hanging TOO loose, or TOO tight, and the y-pipe meets the headers without force, I don't see any reason they wouldn't hold up.
But then, that goes for the JBAs too
Old Mar 13, 2009 | 11:23 AM
krewat's Avatar
krewat
I know ... that "ferritic" stainless probably also holds a magnet too, doesn't it?
Old Mar 13, 2009 | 12:28 PM
dkf's Avatar
dkf
400 series is pretty magnetic and also cheaper than 300 series. 300 series stainless is mostly iron just like the 400 series but the 300 has a higher content of nickel, chromium and other alloys which knocks down the magnetic properties for the most part while greatly increasing corrosion resistanse. 400 series is also able to be hardened and then should be passivated to make it resistant to corrosion. Main reason 400 series is used is to keep the cost down. Nickel is mucho expensive, more nickel and other alloys equals more money.
http://www.mcmaster.com/#8984kac/=zinf9
Old Mar 15, 2009 | 10:51 AM
meanv10's Avatar
meanv10
McMaster-Carr
That's about right, 300 series can be hardened through alloying elements,
as a rule of thumb, It is never hardened with carbon like steel if it is then it forms Chromium carbides, and if to much carbon is present then it will become a martensitic stainless.
300= austenitic and is non magnetic, unless it is work hardened then it becomes magnetic. But grade 329 is a Duplex stainless so it si authentic and ferritic at the same time, its split 50/50 to cut down on chloride stress corrosion cracking.
400= this scale is strange because depending on the grade it is either ferritic or martensitic stainless, they are both magnetic. But very different.
BTW: DFK, you know alot about metals, you going to school for it?
Old Mar 15, 2009 | 05:53 PM
dkf's Avatar
dkf
I'm a machinist. I cut, form and weld metals (stainless included) on a daily basis. But yeah I did go to school for machining and metalurgy was a required class. I learned a lot on my own by reading also.
jbas
Sep 20, 2020 12:23 PM
Thorium
New Member Introductions
Oct 17, 2016 03:21 PM
jbas
Oct 10, 2016 07:46 PM
jbas
Sep 19, 2016 11:34 PM
jbas
Jan 12, 2016 09:27 PM
