adjust speedo with SCT Livewire?
Old Mar 3, 2009 | 09:56 AM
texans's Avatar
texans
how many revolution do I need to set it too I have 285-65-18's. thanks for the help
Old Mar 3, 2009 | 10:35 AM
cartmanea's Avatar
cartmanea
Programmers cannot adjust the speedo, they only correct for shift points. You need about 640 revs/mile (from Toyo AT datasheet for that size). If you want to correct the speedo you can have a dealership reprogram the ABS module for that size tire, they can adjust for up to 35" tires. Another option is to install something like the Superlift TruSpeed which modifies the signal from the ABS module to the PCM to show the correct speed. FYI, I checked with my local dealership and to reprogram the ABS module it was around $45 here. I plan to get mine done since I changed gears and run 35s, I want it to be correct when I don't have the tuner on it.
Old Mar 3, 2009 | 11:39 AM
texans's Avatar
texans
ok thanks cartmanea
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
