stock specs.
Old Mar 3, 2009 | 06:33 AM
badas4.9l's Avatar
badas4.9l
stock specs.
what are the stock specs for a 78 351m????
Old Mar 3, 2009 | 11:18 AM
mark a.'s Avatar
mark a.
What specs ?
Old Mar 3, 2009 | 11:44 AM
hollenjoe's Avatar
hollenjoe
hp: 152 @ 3400
torque 262 @ 2000
8:1 Cr
Old Mar 5, 2009 | 05:22 AM
bigunred's Avatar
bigunred
Slow and steady?
Old Mar 5, 2009 | 07:49 AM
hollenjoe's Avatar
hollenjoe
although weak as it sounds, Its not expensive to turn it into a 400 monster...
Old Mar 5, 2009 | 08:39 AM
likethefords's Avatar
likethefords
I sure love these engines, you can really make them throw out the torque with a few fairly simple mods and they can take a beating too.
Old Apr 2, 2009 | 04:21 PM
ltlvt's Avatar
ltlvt
Like what kind of mods are we talking about. thanks
Old Apr 2, 2009 | 07:38 PM
likethefords
Well I think a good cam and timing chain are the best place to start. Personally I really like the Comp XE256. Headers, intake, and a good carb. Also I must say i'm a huge fan of the DUI Distributor. I recently installed one and I'm very happy with it. These are some of the easier mods to do. Of course you can get much deeper and bump compression, etc. I had to build on a budget however and added one thing at a time. If a person had to start with one thing, I would do the cam first as it affects the rest of the build down the line.
Old Apr 2, 2009 | 08:50 PM
hollenjoe's Avatar
hollenjoe
a great mod would also be turning it into a 400 by simply changing the pistons and crank...
Old Apr 3, 2009 | 11:29 AM
ltlvt's Avatar
ltlvt
If you go to the 400 crank and pistons do you have to grind clearance for the crank like you do for a 383 chevy? Thanks
Old Apr 3, 2009 | 11:57 AM
justforkicks's Avatar
justforkicks
Smile
no, the 351m and 400 are the same block. no grinding needed! everything should drop in perfect, you'll be pleasantly surprised at how easy it can be.
Old Apr 3, 2009 | 11:58 AM
justforkicks
i also heard that the summit 5201 cam is a good choice. i was planning on buying one myself, but i'm broke (not hollywood broke, i mean broke broke)
Shernius
Mar 3, 2005 08:26 AM
RiveraD123
Apr 9, 2004 09:32 AM
bigsnag
Mar 7, 2002 01:14 AM
xaviar
Aug 30, 2001 08:03 PM
