Sponsored by: Real Truck
Thrust Angle adjustment
Old Mar 3, 2009 | 12:56 AM
richsoucie's Avatar
richsoucie
Anyone know how to adjust the thrust angle i just got an alignment and my thrust angle is +1.01 degrees and they said it is not adjustable
Old Mar 3, 2009 | 06:48 AM
aldridgec's Avatar
aldridgec
It's not adjustable, you must have something bent.
Old Mar 3, 2009 | 08:01 AM
Stone Mathews's Avatar
Stone Mathews
I've seen thrust angles all of the place, with little to no issue, and nothing being bent. Like Chris said, however, they aren't adjustable, that I know of.
I have seen them vary from shop to shop on the same vehicle. (And for reasons I don't understand, I've seen thrust change slightly after making changes to the front of the truck, toe, camber, etc. I've always suspected it was just the margin of error in the equipment.) How far is that outside of the 'acceptable range'? I can't remember.
Stone
Old Mar 3, 2009 | 09:02 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Are the leaf spring bushings worn in back (or front) ???
Check out the springs in back (and front if they are leaf-springs) and make sure the center pin/bolt is basically in the center of the axle, and everything looks like it's lined up correctly.
Weird things have happened before, and I've heard of u-bolts getting loose (especially when doing a lift, or doing other work without using new u-bolts), and the center pin/bolt of the spring has it's head sheared off.
Old Mar 3, 2009 | 10:15 AM
cartmanea's Avatar
cartmanea
You can knock the rear u-bolts loose and fudge one side forward and the other side back a little bit. Don't know if that will get you enough though. My truck was totaled when I bought it, hit in front corner, left frame rail pushed back. After pulling it square there was still about 1% thrust but I haven't worried about it yet. Its not enough to see it dog-tracking going down the road.
ybnormal70
Aug 9, 2017 08:49 AM
ATP
Nov 29, 2015 09:14 PM
v10kenj
2009 - 2014 F150
Jan 10, 2014 10:10 AM
bobbyrjw
Sep 24, 2011 06:05 AM
guthrie&co
Mar 25, 2009 06:46 PM
