Sponsored by: Real Truck
Alignment F250
Old Nov 13, 2015 | 08:02 AM
ATP's Avatar
ATP
Alignment F250
I have a 2009 F250 with 13,000 miles.
I took it to a ford dealer the other day to have alignment done.
I had them print me the before and after specs. I was alittle amazed the before and after printouts were only 2 minutes apart..
My question is..was this guy lazy or are these numbers (especially the thrust angle) normal for a stock 250?
Old Nov 13, 2015 | 09:15 AM
nojoke327's Avatar
nojoke327
There are no adjustments to be made on the rear with a solid axle.
Old Nov 13, 2015 | 06:17 PM
ATP's Avatar
ATP
I thought that, but is it normal to have these numbers. The truck is not worked as you can tell by the miles (Ive had it since new). Ive had 1500 chevy and gmc's in the past and dont remember these numbers being that askew. Thanks
Old Nov 14, 2015 | 07:43 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Twin "I" beam... not upper/lower "A" arm... completely different...
Old Nov 14, 2015 | 08:20 AM
scottscott's Avatar
scottscott
I'd say the mechanic checked the readout, saw it was just about right to start with. Bounced the truck a couple of times, which is enough to change the readings a little. Hit done, & printed it out. Never turned a wrench at all. That is why the times are 2 minutes apart. They didn't do anything other than put it on the rack.
I'd say the rear axle is very slightly cocked to one side. Probably not a big deal.
Old Nov 14, 2015 | 08:28 AM
Chuck's First Ford
I am not disputing any of this..
my 1988 Acura Legend.. went from 1990 to 2008 and 200,000 miles before it NEEDED an adjustment... was always "GOOD" and 2 sets of tires went 80,000 each.
modern electronic alignment machines are great and FAST. if NO adjustment is needed.
Old Nov 14, 2015 | 09:55 AM
redford's Avatar
redford
FTE Leadership Emeritus
I think the time of the printout just reflects when the sheet was printed. Alignment measurements can be stored, recalled and printed, which in no way reflects the work performed.
Old Nov 29, 2015 | 02:56 PM
ATP's Avatar
ATP
So, is this normal? If you checked new on the lots they may look like this too?!
Is there anything that can be done to get the thrust angle more centered?
Old Nov 29, 2015 | 09:14 PM
nojoke327's Avatar
nojoke327
You are good. The rear end has rubber bushings in the springs that can move a little. If before it stopped one brake grabbed a little more then another it could easily move the rear a little.
Filko
18
Jan 15, 2015 01:46 AM
DSN46
Feb 23, 2013 10:03 AM
BolderKeith
Apr 20, 2006 06:02 PM
doc526
Jan 20, 2006 06:35 PM
roaky81
Nov 10, 2004 09:22 AM
