quick question
Old Mar 2, 2009 | 08:37 PM
21411's Avatar
21411
Question quick question
in my 64 i've got the custom cab lower dash with 6 spots for controls. but i've only got 5 filled, i've got wipers, lights, lighter, choke, and heater control.
so what goes just to the right of the sterring wheel? theres a toggle there now that is not connected to anything.
Old Mar 3, 2009 | 04:34 AM
camperspecial65's Avatar
camperspecial65
prolly a blank hole plug. These trim bezels were all punched, as were the dashes with the same number of holes on the lower section for the switches. whenever a certain thing wasnt ordered a stainless hole plug was popped in the hole to cover it and make it look pretty...
- cs65
Old Mar 3, 2009 | 07:06 AM
jowilker's Avatar
jowilker
You might fit a kill button in the spot. You know for when that SOB that just cut you off on the road and flipped you da bird at the same time needs a little rebuttal.
John
Old Mar 3, 2009 | 09:37 AM
21411's Avatar
21411
so that would be a good place for a flame thrower switch
Old Mar 3, 2009 | 11:29 AM
59INA40's Avatar
59INA40
One of the control positions is for emergency or 4 way flashers if that was ordered or available for your year. Another **** that you will see on larger trucks is a throttle control ****. Even though throttle control was not available on pickups (to my knowledge) the dash panels are the same for many sizes of truck cabs so the hole options are prepunched for all. Steve
Old Mar 3, 2009 | 11:36 AM
21411's Avatar
21411
new question
so it was a blank that someone punched out for whatever that toggle was hooked up to.
now if you don't mind my asking what are the 6 controls on your trucks?
Old Mar 3, 2009 | 02:59 PM
59INA40's Avatar
59INA40
The three spots on the left of the steering column are from left to right, Headlights, Wipers and Lighter. The three spots on the right of the column are from left to right, Emergency Flashers (with the indicator light just to the left of this ****), Choke and Heater Fan. Now for your further information, The spot just above the ignition switch is where my windshield washer button is located. There is a spot on the opposite end of the dash (far right) where there is another spot just like the one over the ignition switch. In the case of remote vent controls, these spots are where the vent pulls are located and the washer button is relocated usually near the wiper switch. The above configuration is on my '66 F100 and it is stock. Steve
Old Mar 3, 2009 | 04:18 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 59INA40
The three spots on the left of the steering column are from left to right, Headlights, Wipers and Lighter. The three spots on the right of the column are from left to right, Emergency Flashers (with the indicator light just to the left of this ****), Choke and Heater Fan.Steve
Most of these trucks did not come with emergency flashers...because thru 1966....it was an optional accessory.
If you had an F350/600, the "Throttle Cable" went into that position.
The heater and cigarette lighter were also optional accessories. If not ordered....the same stainless steel plugs were used to fill the holes.
Old Mar 3, 2009 | 04:31 PM
21411's Avatar
21411
thanks for the responces. big help i was getting worried that there was some major issue.
Old Mar 3, 2009 | 04:38 PM
CMPFab's Avatar
CMPFab
You could put a cargo light switch in there. Remember that the bezels are the same all the way through 1972, so that opens up your options a little bit.
My 66 F350 has the LH vent above the ignition (no rh vent though!?) lights, wipers, lighter, choke, throttle, and heater below the I/P. Located on the I/P is a "blink marker light" momentary switch and an emergency flasher. On a panel below the dash is Cargo light, flasher light (beacon) and back up lights.
Old Mar 3, 2009 | 05:19 PM
tlk50's Avatar
tlk50
Exactly the Same
One of my 65's is exactly the same! Emergency 4-way lights is missing and plugged on the other!
Tim
Old Dec 8, 2009 | 07:13 PM
jgo427ss's Avatar
jgo427ss
I'm looking for athrottle cable for 66 f100 352 v8
Old Dec 8, 2009 | 07:52 PM
Imspry1964's Avatar
Imspry1964
I have a 64 F100 Custom Cab, and mine is a blank. I have a photo of the dash in my garage.
Old Dec 9, 2009 | 04:16 PM
dman2008's Avatar
dman2008
I say put a button in for a train horn!
Tdogg0413
All Things Towing
Jul 26, 2016 08:02 AM
Bird-Dog 250
23
Jan 9, 2016 01:55 PM
dh_meyer
2009 - 2014 F150
Jul 6, 2015 09:35 AM
jb9339
All Things Towing
20
Feb 27, 2008 12:16 AM
jniolon
Electrical Systems/Wiring
Feb 25, 2001 04:09 PM
