axle identification
Old Mar 2, 2009 | 08:20 PM
Lonewolf0804's Avatar
Lonewolf0804
axle identification
i just pulled the axle tags from my truck and after some searching i didnt come up with much clearification. so if anyone can help me decode these would be greatly apreaciated.
p.s. also have another front axle going in the truck so i am trying to make sure i have the info so i can put it in and to see if i need to change the gear ratio. these tags are from a 90 F-250 4x4
the tags are as follows
Front: 4.09 upside down triangle E8TAUCV 610311-2
Front axle to be put in: 4.10 upside down triangle E8TA YC 610312-2
Rear: V131C 10 10 2 0C15
Old Mar 2, 2009 | 11:43 PM
deeznuts822's Avatar
deeznuts822
Check the code on the door jab, loooks to be 410 in front,which is pretty obvious. I have the code book that came with my truck,if u post the code
Old Mar 2, 2009 | 11:53 PM
Blue Rebel's Avatar
Blue Rebel
Rear axle will be the sterling 10.25 either full or semi float
front look at your hubs. if they are 3" across, its a Dana 44HD. if theyre 4" across, its a D50
Old Mar 2, 2009 | 11:57 PM
85e150's Avatar
85e150
V131C = F-250/350 PU '87-'96 4.10, 10.25 ring gear, limited slip.
Dirty Offio
Jul 23, 2016 12:54 PM
David Greenhalgh
13
Jan 7, 2016 04:54 PM
ScottInTexas
Dec 27, 2015 10:41 AM
ScottInTexas
Jun 11, 2015 04:12 PM
Shawn63200
Mar 12, 2010 02:20 PM
