So I think this is a Dana S135. According to what I can find at AllDataDIY. The tag on the differential reads
4.10 V2C34 UB (The V is actually an upside down triangle)
606775-5 1-S
My differential trashed itself today. I need to rebuild it, but since I've never done it I am a little nervous about starting. At the very ;east I need to identify it so I can do more research.
Reason: Add Photo
If it is a SRW it is probably a Sterling 10.25/10.50" If it is a DRW it should be a Dana 80. Also the axle code you need should be on the door pillar, not the axle itself.
