Gear ratio
Old Mar 3, 2009 | 12:54 AM
br1987's Avatar
br1987
Gear ratio
By the sticker on my door jam i have the H9 differental and 3.55 gears. I need to find out what ratio i need to get if im looking to drop my rpms when i am going 40 mph i am running almost 2300 rpms and it is a 4 speed with a granny. please help
Old Mar 3, 2009 | 01:25 AM
85e150's Avatar
85e150
Your trans would have a 1:1 4th gear.
With 29 inch tires, (stock height) 3.55s and a 1:1 gear, you should be turning 1645 rpm at 40 mph.
At 55 mph with that combo, you would turn 2262--
You would need 4.88s to turn 2261 at 40, close to your claimed 2300. 55 would then be 3110
If you have a T19, all synchro 4 speed with granny first, your 3rd gear is 1.79, which would result in 2945 rpm at 40.
If you have a NP435, 3rd would be 1.66 or 1.74, for 2731 or 2863 at 40.
Something is wrong here--is there a tag down on the axle? If so, post those numbers. What trans do you have? What size tire? Are we really talking 40mph?
Once we figure this out, if you are still geared too short, you can either convert to a 5 speed, or change the axle, but let's get a correct base line figure to start. BTW, what tach are you using to check rpm to mph? And does your speedo read correctly?
Old Mar 3, 2009 | 07:18 AM
Rulebreaker's Avatar
Rulebreaker
Easy way to lower rpm is a taller tire. Your speedometer will read low but that can be fixed. RB
Old Mar 3, 2009 | 07:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
H9 = Ford 8.8 / 3.55-1 / Limited Slip / 3750/3800 lbs. Rear Axle Capacity.
1955 f250
Oct 14, 2014 09:24 PM
RoofDude
6.4L Power Stroke Diesel
Jul 6, 2013 09:05 AM
therigwelder
Nov 23, 2010 11:03 PM
fastestbbc
Nov 20, 2008 07:56 AM
sbeazel
2004 - 2008 F150
Oct 18, 2004 04:25 PM
