Hutch Mod Options??
Old Mar 2, 2009 | 11:34 PM
jkidd_39's Avatar
jkidd_39
Originally Posted by jeff7825
Why didn't I think of something like that. Like an idiot I was laying there letting the fuel drain into my pan thinking it would stop, but it drained way more than I thought it would and finally I just put the filter in and tightened everything down.
Instead of using vice grips couldn't you just put a brass valve on each side of the filter and just close them when you change filters?
Anyone mount it in your bed? Like the airdog
Old Mar 2, 2009 | 11:49 PM
jeff7825's Avatar
jeff7825
IMO, on the frame rail is the best option. If you put it in the bed, then you would have to drill holes for the fuel line, come up with a way to mount it and so on. Then you would have to worry about thing you put in the bed sliding into the filter and knocking it loose, knocking a hole in it, etc. Then your in for a big mess and making things harder than it needs to be. If I were you I would show your boss the ITP kit, and their instructions that can be viewed online on their site, and also show him the pictures in this thread. The screw on filter in their kit should be even easier to change than the one that either Joe or I have, I would think.
Old Mar 2, 2009 | 11:57 PM
jkidd_39's Avatar
jkidd_39
Well it's me and my dad's company.. it's so weird to hear people say "your boss" haha.. I guess thats what I call him when he's being a d1ck.
I really think I'm just gonna do it myself.. F him.. he'll be mad for a week.. His whole argument is there is no way he's gonna crawl around on the ground to change a filter.
Regardless of it's ability to filter fuel better and keep out air.. don't matter to him.. he is in that demographic of "stock is just fine"..
This is situation is starting to look like the situation that got me this truck.. he went and bout a $250,000 motorhome without discussing it with me.. so I got pissed and went and bought this truck.. haha
Old Mar 3, 2009 | 12:01 AM
jeff7825's Avatar
jeff7825
Well you called him "boss" in your first post, so that's why I was referring to him as such. If it's your truck I assume that you will be changing the filters on it, so I wouldn't worry too much about it then.
Old Mar 3, 2009 | 12:05 AM
jkidd_39's Avatar
jkidd_39
Yeah.. i'm just trying to find the happy medium of the situation.
Thanks to everyone for the help.
Old Mar 3, 2009 | 12:08 AM
jeff7825's Avatar
jeff7825
Yeah I understand that. I would still do what I said in my previous post and see what he says and then go from there. Good luck to you.
Old Mar 3, 2009 | 07:30 AM
firemediceric's Avatar
firemediceric
I use the Dahl 100 with the 2 micron element. I really like how it seperates the junk out with gravity before it even hits the element. When I did the mods I upgraded to 3/8" fuel hose for less restriction. At that time I also put in a ball valve to shut off the fuel at the fuel filter. Makes changing the filter neat and easy, although I get about 18 months of filter life before the vacuum gauge shows that it needs changing, so regardless, it's not a big deal.
Good suggestion about putting a section of hose on the drain tube from the fuel bowl. I did the same thing. I chose oxygen tubing, as the female end of the oxygen tubing is a perfect friction fit without clamps. That made installation a lot easier for my fat hands. I left it in place and cut it so it hang below everything else. This allows me to drain the fuel bowl into a bottle so I don't make a mess when draining a few ounces out of the fuel bowl every few months.
Old Mar 3, 2009 | 08:30 AM
sflem849's Avatar
sflem849
Originally Posted by Izzy351
Jeffrey, I use two sets of vice grips to pinch off the lines to keep it from dropping too much fuel. Some does come out of course, but it helps with the hose crimped.
Light bulb moment!!!
To think last time I changed mine I was eating fuel and had well lubricated eye *****...
Old Mar 3, 2009 | 10:31 AM
Izzy351's Avatar
Izzy351
Sure could! I'm cheap though -- already had a couple pair of vice grips in my tool box...
Yeah, it will start siphoning out of the tank on that side, so it would take a while before it stopped. LOL....
Old Mar 3, 2009 | 11:04 AM
danskool's Avatar
danskool
Go Bills !
Here's an easier tip -- jumper your fuel pump to the battery, attach a piece of hose (I used the one that came with the kit ) to the filter housing drain, open the valve, and pump your fuel into a couple geri cans. The tank is plastic and very light when empty. I just unbolted the straps and pulled it out. I used my floor jack to hold it up while I bolted it back in.
That is what i didn't last summer when i did mine.. But the only problem I had was the hose popped off on the back of the water seperator. There wasn't any clamps to hold that little 1" long hose on there. "connects the seperator to the tubing" I tossed on a couple clamps and away i went. The fuel tank was only 20lbs if that empty
Old Mar 3, 2009 | 11:20 AM
sflem849's Avatar
sflem849
Yepper, I realized it was siphoning the tank so I just went nuts and shoved the filter in as fast as I could. The real pain was I did the mods about a week before and didn't put a filter in so I had to cut the hose, slide four clamps on THEN I could shove the filter in.
It worked...eventually. I did have to throw the shirt out when I was done. It looked a lot like the shirt I did my JW Valve Body in.
Old Mar 3, 2009 | 04:10 PM
King0581's Avatar
King0581
I'm not sure about these fuel pumps but I dont know how well they would suck the fuel up and in to a filter if you moved it under the hood or in the bed. I'm sure it would do it but not sure how long it would last. As stated...I HAVE NO IDEA ABOUT THIS. I'm just throwing it out there. I have my filter mounted where the one in the picture above is and I have a ball valve on each side of the base. Been running it like this for a year and love it.
savagebagz
47
Feb 6, 2015 09:15 AM
johnarahill
23
Jun 30, 2013 06:24 PM
Bigtruc
Jan 1, 2013 08:39 PM
Chipworkz
22
Apr 15, 2012 02:59 PM
shadetree01
19
Jan 29, 2008 10:40 PM
