anyone that has a front driveshaft from a ford f-350 with an e4od. i am in dire need, 10 inches of snow on the way and i am still in a crippled 4wd....... it must be a 350 as i need the double cardon joint. thanks!!!!
yup, wasnt the case, i need the 350 shaft with the double cardon joint.
Joe do you currently run that shaft or you need to make the switch? If you are making the switch just a heads up but the yoke for the t-case is different between the two. You may already know that so if you do never mind.....
joe,
i called all the yards in the area i normally use including buck, and baughman's in york and no joy on the d.s. have you tried stateline salvage yet? right on 272 at the md line.
has to be an e40d truck, the stick trucks and c-6's are the wrong length.
and yes i tried stateline, no go
what about the two big yards up past cabela's north of reading? ever been to either of them? the farther one is huuuuge! i'll have to try to remember the names. been probably 2 years since i was there last.
I am 98% sure that it was an e4od but I can find out. I can check the junkyard up the road from me tomorrow, they had a complete 97 350 psd with an auto so they may still have one. How much is one of these worth?
