trans qeustion
Old Mar 3, 2009 | 10:39 PM
don77's Avatar
don77
trans qeustion
i was thinking about just using the 2wd trans the electical stuff still the same right i dont need the transvere case so qeustion is is the computer the same im fixing to get me trans ilike to just put 2wd one
Old Mar 3, 2009 | 10:46 PM
joe_13894's Avatar
joe_13894
I'm having a bit of an issue following you.
Are you saying that you have a 4x4 truck, but you're just considering putting in a 2wd transmission and skipping the transfer case?
If so, you'll be fine. The computer is the same. There is a wire on the transfer case that is grounded that tells the computer to shift right in low range. With the wire taped off, nothing will happen.
Old Mar 3, 2009 | 10:52 PM
don77's Avatar
don77
thinks thats all i wanted to no so just the ground on transfer case oh and yeah thats what i was asking
