another turbo ?
Old Feb 28, 2009 | 09:04 PM
jimwilsonmasonry's Avatar
jimwilsonmasonry
another turbo ?
i found a guy on craigslist really close to where i live and ive already seen them but he has two brand new turbos one is a 99-03 the other is a early 99 my ? is will the early 99 bolt up to my truck and will it be a upgrade and there dirt cheap as well
Old Feb 28, 2009 | 09:16 PM
ahughes's Avatar
ahughes
they should bolt up just fine
Old Feb 28, 2009 | 09:21 PM
jimwilsonmasonry
so a early 99 turbo will directly bolt on its got the pedestal and all on it and will it be a upgrade the intake side is .110 the exhaust side is .84
Old Feb 28, 2009 | 09:32 PM
ahughes's Avatar
ahughes
yes it should bolt up just fine and it should give you more power because i think 99 in when they went to the bigger turbo i have a friend that ghanged his for that reason
Old Feb 28, 2009 | 09:44 PM
jimwilsonmasonry
the superduty and the early 99 are smaller turbos
Old Feb 28, 2009 | 10:01 PM
ahughes's Avatar
ahughes
i thought 99 started the bigger turbos
Old Feb 28, 2009 | 10:39 PM
jimwilsonmasonry
so what do you guys think should i get the early 99 turbo
Old Feb 28, 2009 | 11:12 PM
phillips91's Avatar
phillips91
the 99 is a smaller turbo, so it will spool up faster than the obs. where ours makes peak torque at 2k rpm the 99 makes peak torque at around 1600 rpm. if your truck is mostly stock, the 99 would be a good upgrade. but if you plan on making monster numbers, having a bigger turbo would be more beneficial.
Old Mar 1, 2009 | 02:08 AM
jimwilsonmasonry
yea but is it a direct bolt on
Old Mar 1, 2009 | 05:12 AM
WALJON's Avatar
WALJON
No it is not
Old Mar 1, 2009 | 07:31 AM
tjbeggs's Avatar
tjbeggs
Not even close to a direct bolt up without change a bunch of other parts. And to do the change over is not worth it either. Unless you are going to put a Garrett BB turbo in.
bigbubba87
Aug 23, 2014 10:58 AM
Bonanza35
13
Dec 14, 2010 10:00 PM
ltl_jrw
Dec 1, 2009 03:31 PM
wilbur996
Feb 8, 2009 06:42 PM
troubledsol
13
Jan 11, 2007 10:34 PM
