Turbo different E99
Old Dec 14, 2010 | 12:42 AM
Bonanza35's Avatar
Bonanza35
Turbo different E99
Besides uppipes what is the difference between the early and late 99 turbos. I know about the intake wheel but is that all. I want to up date my system but dose the complete turbo have to be changed. Thanks Chet
Old Dec 14, 2010 | 01:45 AM
Pocket's Avatar
Pocket
Yes, turbos are completely different. The compressor out-pipe is a different size. The height of the turbo mounts are different.
They are not interchangeable.
Old Dec 14, 2010 | 03:30 AM
farmb0y's Avatar
farmb0y
Yep, most everything on the intake side has to be changed, been there and done that.
What are your plans for the truck? The update isn't a very cheap option.
Riffraff Diesel: Early/Late Conversion Kit
That'll give you an idea of the costs (which is probably the cheapest way to go), that's not including a new turbo. I'd take the money and spend it on a good exhaust, intake, gauges and chip and be money/hp ahead.
Old Dec 14, 2010 | 06:43 AM
Franko72's Avatar
Franko72
Molon Labe
I agree with farmb0y, I tow regularly with my e99, and the bosses 01.
both have 6637, 4" exhaust, and Dp tuners. I honestly cant feel any difference between the two when it comes to power.
It may show up on a dyno, but not SOTP.
Just my .02
Old Dec 14, 2010 | 09:20 AM
PaysonPSD's Avatar
PaysonPSD
Upgrading the pedistal, up-pipes and spider will allow you more options for turbo upgrade. As far as upgrading to the later intake plenums it is really not worth the effort and Riffraff now has reinforcement inserts for the early 2 1/2" plenums.
Another way to go is a Beans E99 D66 Dominator Turbo. It is a direct drop-in for E99s.
Early 1999 Power Stroke BDP Dominator 66 Turbo
Old Dec 14, 2010 | 12:52 PM
Bonanza35's Avatar
Bonanza35
My build date 9/98 cc 4x4 lb dually pds and the dealer put on the late air intake when it was new. Question, I haven't seen the difference between the very early and mine but dose the early all have reducers coming from the spider to the intake at the block. Because it would seem to me if they had to reduce it there I mit just have the late model spider. Also with the late model spider would come the late model turbo? Thanks guys this is important to me I'm going to order some things from Clay and it mit save some head aches. God Bless Chet
Old Dec 14, 2010 | 03:57 PM
rat49f6's Avatar
rat49f6
9/98 should be early99
only difference between e99 and 99.25 is the front leaf springs and brakes
chet does your truck have a aih???
also the reduced boots will be the ones that go from the plenum to the spider
Old Dec 14, 2010 | 04:24 PM
farmb0y's Avatar
farmb0y
If you have an e99, your boots from the spider to the intake plenums should look like the one on the left. The later model is the one on the right. These pics are from when I upgraded mine, showing the difference between the two.
Old Dec 14, 2010 | 04:32 PM
rat49f6's Avatar
rat49f6
thanks adam u have a pic showing the 2 different spiders by chance???
Old Dec 14, 2010 | 04:38 PM
farmb0y's Avatar
farmb0y
Just got one of the early spider. Notice how the "tube" going to the right into the IC pipe is reduced, on the later models it's all 3". As well as the intake boot going into the turbo, it's 4" (I think) all the way, were the early's are reduced.
Old Dec 14, 2010 | 04:58 PM
superduty4x4's Avatar
superduty4x4
The stock E99 and late99 intake on the turbo is 3". The ATS housing and the 38R are 4".
Old Dec 14, 2010 | 09:02 PM
farmb0y's Avatar
farmb0y
Yep, you're right Chase, I went from the e99 setup to a late with the 38R.
Old Dec 14, 2010 | 09:53 PM
Bonanza35's Avatar
Bonanza35
rat49f6, I don't have the AIH. I'll have to check the other boots. I think all my other boots are 3 inch. Except the pleum to spider. Great pictures thanks guys. I'll check tomorrow, I have a full day but will be back tomorrow night. Chet
Old Dec 14, 2010 | 10:00 PM
Bonanza35's Avatar
Bonanza35
Also other then the aih hole is the spider the same as the late model as far as opening sizes etc.?
travisp_95
Oct 6, 2012 05:11 PM
7.3 Rocket
25
Nov 4, 2010 11:13 AM
proudtruck
Apr 17, 2009 09:49 AM
rfrunk
20
Jul 10, 2007 03:43 PM
