Early 99 van on 00
Old Jan 8, 2007 | 01:21 PM
troubledsol's Avatar
troubledsol
Early 99 van on 00
I have come a cross an early 99 van turbo and was curious if it will still work on my 2000 using my pedestal
I did a bit of searching didnt really find the answer
Thanks
Old Jan 8, 2007 | 01:46 PM
dpwilson's Avatar
dpwilson
I would like to know this myself but am hoping for opposite results then you. Kinda hard to find turbo upgrades on an early 99 for reasonable amount of dough.
Old Jan 8, 2007 | 01:49 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
How about that Alan... LOL
Yes it is possible that it will work. It is somewhat of a "downgrade", however because it has the smaller compressor it will be less efficient than a stock turbo's compressor housing. But for $100 including the pedestal you can try it. It will look really funny.
But for DPwilson that is a good upgrade, you won't have to change anything around.
Old Jan 8, 2007 | 02:08 PM
troubledsol
Could I use the compressor housing from my stocker on it I already have a ww for that as well
Old Jan 8, 2007 | 02:23 PM
John311t's Avatar
John311t
Isn't that outlet of the early 99 van turbo smaller than the outlet of the 00 turbo where it comes from the turbo into the 5 way spider?
Old Jan 8, 2007 | 06:40 PM
Uzumati's Avatar
Uzumati
I know what you mean Kris!
Old Jan 8, 2007 | 09:14 PM
troubledsol
So this turbo would not work for my application
Here is the turbo eBay Item number: 300067293622
Old Jan 8, 2007 | 09:16 PM
jtharvey's Avatar
jtharvey
Hmmm....a 99 van turbo. I think I've seen one too.
I would think you would be able to use the compressor housing and backplate from the newer turbo without any problems. I doubt the center section design changed at all.
Old Jan 10, 2007 | 03:56 PM
bigcountry560's Avatar
bigcountry560
The center section and exhaust housing are the same. A seal plate and compressor housing from a late 99 can be used.
Old Jan 11, 2007 | 03:46 PM
troubledsol
How hard is it to swap out?
Old Jan 11, 2007 | 05:23 PM
PowerstrokeJunkie
Check this out
https://www.ford-trucks.com/article/...tallation.html
Old Jan 11, 2007 | 08:18 PM
troubledsol
I know how to do that but how do I swap the backing plate are there seals does it just unbolt
Thanks
Old Jan 11, 2007 | 08:27 PM
PowerstrokeJunkie
Oh for that, you mean. Pull the 5 bolts holding the compressor housing on. Using a 5/8 socket and holding the turbine end nub firmly with a vise grip pliers, remove the compressor wheel. Then there are 4 bolts behind that, same as the compressor housing bolts. Then the backplate just wiggles off and there is a X shaped seal. want pictures?
Old Jan 11, 2007 | 10:34 PM
troubledsol
I will open it up and try it sounds simple enough
Thanks alot
bigbubba87
Aug 23, 2014 10:58 AM
C.W
Modular V10 (6.8l)
Mar 12, 2013 10:23 AM
guyno78
Jan 17, 2011 09:32 AM
Franko72
Mar 31, 2009 10:11 AM
Subdued
Mar 7, 2005 07:24 PM
